Specific heat capacity aluminium
The discussion revolves around an experiment related to determining the specific heat capacity of aluminium. The original poster indicates that their measured value was unexpectedly low and seeks advice on improving the experimental setup.
  • Exploratory, Assumption checking
  • Participants inquire about the specifics of the experiment, including the equipment used and the conditions under which the measurements were taken. There is a suggestion that the original poster's results may have been influenced by the experimental setup.
The conversation is ongoing, with participants asking clarifying questions and exploring potential factors that could affect the accuracy of the specific heat capacity measurement. No consensus has been reached yet.
There is mention of using a good insulator, which may imply considerations regarding heat loss during the experiment. The original poster's results are noted as being lower than expected, prompting further inquiry into the methodology.
Cammers5
An experiment I did I got the specific heat capacity of aluminium to be too low. Anything I could say to improve my experiment?
Eh=cm(delta)T
say I used a good insulator?
Hello CAmmers, :welcome: !
Cammers5 said:
Homework Statement:: An experiment I did I got the specific heat capacity of aluminium to be too low. Anything I could say to improve my experiment?
What experiment ?
With the power supply the 1kg of aluminium and thermometer and I had a meter that could measure heat energy also
Let me guess. Your answer came out too high.
  • · Replies 16 ·
  • · Replies 17 ·
