What is the Specific Heat Capacity of Air at 300K and 1 atm?
hhhmortal
What is the the specific heat capacity at constant volume of Air?, with temperature 300k and pressure = 1 atm.
Do I assume that this is a diatomic ideal gas and thus Cv = 5/2 ?
Thanks.
Try it and see how close you get to the experimental value ?
Cp = 1003.5 J kg−1 K−1
Ok, well I've assumed air is a diatomic gas and that:
Cv = 5/2 R = 20.785
What other equation could I use to work out the precise value of Cv for air?
A few issues with that:
1) "Specific" implies per unit mass, not per mole.
2) Air is a combination of gases, not all of which are diatomic.
3) Air is not a perfectly ideal gas.
4) Additional heat capacity arises from diatomic bond stretching.
Depending on how introductory your thermo class is, issues (2), (3), and (4) may be ignored.
Cv = 20.7643 J mol−1 K−1 for air at STP, pretty close to an ideal gas
You could re-calculate it assuming 1% Argon (the major non-diatomic consituent of air) but to account for the difference between the nitrogen and oxygen is a much more complicated model.
Ok thanks. I might as well post the whole question because I can't seem to get the right answer.
(Q) Find the thermal conductivity of air under the following conditions:
T = 300 K
pressure = 1 atm
density of air = 1.29 kg/m^-3
coefficient of viscosity is 1.75 x 10-5 Pa.s
Average speed of air molecules is 466 m/s
Mean free path of air molecules is 942 x 10^-10 m
Do I use equation:
Thermal conductivity = [n<v>λ / 3][Cv/6.02 x 10^23]
When I do though, I don't get the correct value...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
