- 36,978
- 15,957
What are you referring to by the term "Lorentian redshift"?utesfan100 said:You are confusing Doppler redshift with Lorentian redshift. In fact, both are present.
As has been mentioned a couple of times the part where you are wrong is the idea that the waves move at c+v instead of c. The fact that light always moves at c regardless of the motion of the emitter is called the second postulate of relativity and has been experimentally confirmed many times to very high precision:sisoev said:In my experiment we observe it the other way round - the observer is stationary and the waves move toward him with speed c+the speed of the train, and that is why the frequency is different for B. Well, this is how I see it. Where am I wrong?
Did I just stupidly broke some law of the physics![]()
DaleSpam said:
DaleSpam said:My apologies, you certainly did, even to linking right to the same sub-section.
utesfan100 said:The speed of light is not C+V(train).
The length ot the train would be contracted just enough to make the light travel at C.
DaleSpam said:What are you referring to by the term "Lorentian redshift"?
utesfan100 said:Lorentzian redshift was ment to refer to the frequency shifting caused by the length contraction of the wave lengths in different reference frames (if viewed from an observer moving in the same direction of the light relative to the original observer).
Doppler redshift is cause by wave lengths expanding as the source moves away from an observer (with the source having a set frequency).
I am thinking that these two are not as distinct as I was thinking yesterday.
utesfan100 said:Suppose the experiment was ran perpendicular to the motion of the train. Then the doppler effects and length contraction effects would be orthogonal and could not cancel.
DaleSpam said:Length contraction really doesn't apply for wavelengths of light. Length contraction refers to a reduction in the length of a moving object compared to its length measured at rest. A wavelength of light is not at rest in any reference frame so there is nothing to compare it to.
Squashed or stretched depending on the direction, yes. E.g. for an emitter moving at v=0.6 the Doppler shift is a factor of 2. So if it broadcasts a 1 s transmission in front then it will be blue-shifted to a 0.5 s transmission, if it broadcasts the same transmission behind then it will be red-shifted to a 2 s transmission.kamikaze762 said:I think I already know the answer, but does a pulse emitted from a moving source arrived "squashed?"
starthaus said:Then you would be observing an effect known as "Transverse Doppler Effect". Length contraction has nothing to do with any of this.
Doc Al said:Sure. If the sun disappeared 'right now', we wouldn't know it for about 8 minutes. Nonetheless, to understand how the frequency shifts it's best to imagine the source still there.
That's illustrated in the second animation.
It's not any difference in the speed of the light--the speed of the outgoing waves doesn't change. It's the fact that the source moved while the light was being emitted. Thus the wave crests are closer together.
I think this gets at the heart of the problem. The first animation shows what an observer sees when the source is not moving. The second animation shows a moving source. You can't take the first diagram and then superpose a moving observer on it, just using "common sense". Light doesn't work that way. (Otherwise the second animation would be wrong.)sisoev said:The second diagram is a quite deceiving.
The source is always in the center of the emission.
To imagine a moving source use the first animation and set the blue observer moving toward the center and the read observer out of the center.
You will see that the blue observer is approached faster by the light wave, while the red observer is approached slower by them.
Actually, just the opposite. The light is always moving at the same speed with respect to the observer, not the source.It is true that the speed of the light waves is always the same in respect to the source (I mentioned it in my OP) but that does not apply to the observers.
It might be 'obvious', but it's not true.Obviously when the source or the observer is in motion, we observe different velocity between the light waves and the observer, and that is what we call "measured speed of light".
A thought experiment can only show where your assumptions and your physics lead you. (Garbage in, garbage out.) Only real experiments can determine which assumptions are correct. Real experiments overwhelmingly support Einstein's assumptions and conclusions. (See the link that has been provided several times in this thread and also happens to be contained in a sticky at the top of this forum.)We don't measure the speed of light in respect to the source, do we?
Einstein postulated it as measured in respect to the observer, and by my opinion he was wrong, and this is what my experiment shows.
You are wrong because you are using the first animation and trying to apply it to a moving source. That implicitly assumes that the light is moving outward at a constant speed with respect to some medium (what used to be called the 'aether'). Then you add a moving observer traveling through that medium towards the light source. You merely assume that by moving towards the incoming light the speed of that light with respect to you must be faster. That was shown to be a false assumption many years ago.I'll ask again WHERE AM I WRONG but I can see that we are already in a corrupted circle.
How can we get out of it?
Doc Al said:I think this gets at the heart of the problem. The first animation shows what an observer sees when the source is not moving. The second animation shows a moving source. You can't take the first diagram and then superpose a moving observer on it, just using "common sense". Light doesn't work that way. (Otherwise the second animation would be wrong.)
.You are wrong because you are using the first animation and trying to apply it to a moving source. That implicitly assumes that the light is moving outward at a constant speed with respect to some medium (what used to be called the 'aether'). Then you add a moving observer traveling through that medium towards the light source. You merely assume that by moving towards the incoming light the speed of that light with respect to you must be faster. That was shown to be a false assumption many years ago
Light doesn't work in that 'common sense' way. Actually, space and time do not work that way. You can't take reasoning that works well enough in everyday, low-speed situations and apply it to things moving at high speeds (like light).
sisoev said:Well, if the light is not always moving at the same speed in respect to the source, one cannot claim that it always move with the same speed in respect to the observer.
"Faith" has nothing to do with it. You make assumptions, draw conclusions, then compare to experiment. Experiment rules!sisoev said:Sir, I was hoping that in forum like this I'd receive more detailed answers than in the books.
I think this is the reason people come here to ask for help ;)
Now your answer "the light doesn't work that way" made me lough, thinking of a priest who told me that God doesn't work that way
Shall we put our scientific knowledge on faith?
It's moving! Note the key assumption of relativity: The speed of light is the same with respect to any observer.What is the logical reason to present the moving light source off the center of its emission.
So you claim.I think that the second animation shows how the observer sees the light waves but that is not the actual way of the light propagation.
Been trying to.If you say that I'm wrong, please explain why, so I can understand the core of the problem.
That 'simple logic' is really a claim about how light works and how velocities add. And it's been shown to be false.Well, if the light is not always moving at the same speed in respect to the source, one cannot claim that it always move with the same speed in respect to the observer.
It is simple logic which involves velocity.
Again, what you are calling "logic" is an expression of how you think the world works. It just doesn't work that way.The experiment I present is thought experiment until someone decides to perform it.
Its based on logic and it predicts results based on logic.
Nonsense.I only assume that the light is moving with the same speed in all directions in respect to the source. If this assumption is wrong then Einstein is also wrong.
Ironically if my assumption is right, Einstein is wrong again.
The explanation is perfectly logical--and I am saying just that and the misunderstanding is on your end. Light always moves with constant speed with respect to the observer. As the source moves from spot 1, to spot 2, to spot 3, etc, expanding circles of light will be centered on spot 1, spot 2, spot 3, etc. Just like the second animation shows.I'm sure you have a logical explanation of why the source should be off the center of the emission like in the second animation (I hope you are not saying that, and this is only misunderstanding)
The answers have all been given. I think what you're really looking for is a way to keep your (mistaken) common sense views of how light works and velocities add and still understand relativity. Sorry, that's not going to happen.Sir, you understand that I am here because I have problem taking this on faith, and I'm hoping for some logical answers.
Help me, please.
I created my experiment as a simple way to show the problem and there should be simple way to give me the answer.
So, follow my questions and give me the answers.
If you're really interested in understanding Einstein and his theory, then you need to be willing to start fresh. There are many excellent books that explain how it all works, but again the bottom line is always: Does it agree with real experiment? Yes!That would be of great help of all that come here with the same question.
Just pin this topic and send them here to read how you explained to that stupid Bulgarian the simple way of understanding Einstein and his theory.
Actually, that is exactly what one can claim, it is the whole point of the http://en.wikipedia.org/wiki/Lorentz_transform" to show that it is logically possible for something to move at c in one reference frame and also to move at c in another reference frame, despite the fact that the two reference frames are moving at some velocity v<c with respect to each other.sisoev said:Well, if the light is not always moving at the same speed in respect to the source, one cannot claim that it always move with the same speed in respect to the observer.
Doc Al said:"Faith" has nothing to do with it. You make assumptions, draw conclusions, then compare to experiment. Experiment rules!
sisoev said:Now, in my experiment we have one only wave length (color) because it is one only emission.
Having two different frequencies, we must have two different speed of the light.
But because SR does not agree with that we end up with the paradox of having two different wave lengths for one emission.
The observed frequency shift of the light depends on the speed of the source, not the speed of the light. Your arrangement leads to multiple frequencies observed because the source is moving and some of the light is reflected from a moving mirror (which acts as a secondary source). In all cases the speed of light is the same.sisoev said:In my experiment you have one source and one emission with one wave length, observed with two different frequencies.
How do you intend to measure same speed for the light?
What paradox? The different frequencies observed are easily explained within SR. Again, it has nothing to do with 'different speeds of light'. You realize, of course, that the same source of light could be seen as having as many different observed frequencies are there are observers moving at different speeds with respect to the source. Why stop at two?Now, in my experiment we have one only wave length (color) because it is one only emission.
Doc Al said:Here's some homework for you. Give the train some relativistic speed (say, 0.9c). And give the light source some original frequency in its own frame (600 nm, say). Why don't you predict what frequencies will be observed?
dx said:Here's a spacetime diagram for your situation as I understand it, in a frame in which B is at rest:
[PLAIN]http://img11.imageshack.us/img11/1161/expnk.jpg
Now can you explain what your problem is with reference to this image? (Keep in mind the time dilation for the moving observers. That affects the frequency that they observe.)
The geometry of space-time will be valid only if the speed of light is constant.Frame Dragger said:Isn't this the precise conundrum that is the basis for SR?... that the geometry of spacetime is altered because "c" represents that limit however one chooses to think of it, or arrive at the conclusion?
I'm not trying to be sarcastic... I just want to make sure that I'm not missing more than usual. To me, this has always been where you start with the notion of Relativity.
