Speed of the rod as it leaves the rails?
  • Thread starter Thread starter nawand
    Rod Speed
The discussion revolves around calculating the speed of a rod as it exits two parallel rails while carrying a current in a magnetic field. The rod, with a mass of 0.720 kg and a current of 48.0 A, experiences a magnetic force that contributes to its kinetic energy. The key equation used is the energy balance between the magnetic force and the kinetic energy of the rod, leading to a calculated speed of 1.07 m/s. Participants clarify terminology, addressing a mistake regarding the inclusion of kinetic energy in the calculations. The focus remains on understanding how the magnetic field exerts energy on the rod as it moves along the rails.
nawand
A rod of mass 0.720 kg and radius 6.00 cm rests on two parallel rails fig.1 that are the d=12.0 cm apart and L=45.0 cm long. The rod carries a current of I=48.0 A in the direction shown and rolls along the rails without sleeping. A uniform magnetic field of magnitude 0240 T is directed perpendicular to the rod and the rails. If it starts from rest, what is the speed of the rod as it leaves the rails?
0+0+Fb *L*cos θ = (mv2)/2 +(Iω2)/2
The rod gains energy from the rest, so begin kinetic energy and rotational energy are zero. The only source of energy rod gains is magnetic filed.
I = (mr2)/2
K=(mv2)/2
w=v/r
That is right side of equations becomes:
(mv2)/2 + 1/2 (mv2)+1/2(1/2 mr2) * (v2/r2)
Fb * L = 3/4 mv2
Where
Fb = I * d * B
etc
v=1.07 m/s
Because the force move the rod parallel to the rails along x axis, the dot product will be:
E=Fb * L * cos θ = Fb*L*1=FbL
The question is how do we get the value of energy exerts magnetic field on the rod?
That is force time Length of rails (Fb times L)?
For the electric field is E = qFe
It looks like you are adding the kinetic energy twice here (highlighted in bold).
The line afterwards is right again.
Sure.
I don't see an electric field.
Slipping, not sleeping, by the way.
Likes nawand
Great!.
Indeed I have added it twice mv2/2 (This is my type fault).
  • I was wondering about the energy was added in the left side Fb times L and which is likely the energy contribution of magnetic field.
  • "Sleeping" = "Slipping"
Thanks a lot!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
