Speed of the rod as it leaves the rails?
  • Thread starter Thread starter nawand
    Rod Speed
The discussion focuses on calculating the speed of a rod with a mass of 0.720 kg and radius of 6.00 cm as it leaves two parallel rails, given a current of 48.0 A and a uniform magnetic field of 0.240 T. The rod rolls without slipping, and the final speed is determined to be 1.07 m/s. Key equations include the force exerted by the magnetic field (Fb = I * d * B) and the energy balance involving kinetic and rotational energy. The participants clarified the correct interpretation of energy contributions from the magnetic field and corrected terminology from "sleeping" to "slipping."
  • Understanding of Newton's laws of motion
  • Familiarity with electromagnetic principles, specifically Lorentz force
  • Knowledge of kinetic and rotational energy equations
  • Basic grasp of magnetic fields and their effects on current-carrying conductors
  • Study the derivation of the Lorentz force and its application in electromagnetic systems
  • Explore energy conservation principles in mechanical systems
  • Learn about the dynamics of rolling motion and the relationship between linear and angular velocity
  • Investigate the effects of magnetic fields on moving charges and current-carrying conductors
Physics students, electrical engineers, and anyone interested in the dynamics of electromagnetic systems and energy transfer in conductive materials.
nawand
A rod of mass 0.720 kg and radius 6.00 cm rests on two parallel rails fig.1 that are the d=12.0 cm apart and L=45.0 cm long. The rod carries a current of I=48.0 A in the direction shown and rolls along the rails without sleeping. A uniform magnetic field of magnitude 0240 T is directed perpendicular to the rod and the rails. If it starts from rest, what is the speed of the rod as it leaves the rails?
0+0+Fb *L*cos θ = (mv2)/2 +(Iω2)/2
The rod gains energy from the rest, so begin kinetic energy and rotational energy are zero. The only source of energy rod gains is magnetic filed.
I = (mr2)/2
K=(mv2)/2
w=v/r
That is right side of equations becomes:
(mv2)/2 + 1/2 (mv2)+1/2(1/2 mr2) * (v2/r2)
Fb * L = 3/4 mv2
Where
Fb = I * d * B
etc
v=1.07 m/s
Because the force move the rod parallel to the rails along x axis, the dot product will be:
E=Fb * L * cos θ = Fb*L*1=FbL
The question is how do we get the value of energy exerts magnetic field on the rod?
That is force time Length of rails (Fb times L)?
For the electric field is E = qFe
It looks like you are adding the kinetic energy twice here (highlighted in bold).
The line afterwards is right again.
Sure.
I don't see an electric field.
Slipping, not sleeping, by the way.
Great!.
Indeed I have added it twice mv2/2 (This is my type fault).
  • I was wondering about the energy was added in the left side Fb times L and which is likely the energy contribution of magnetic field.
  • "Sleeping" = "Slipping"
Thanks a lot!
  • · Replies 25 ·
  • · Replies 31 ·
