How Can the Work-Energy Theorem Be Applied to Calculate Block Speed?
  • Thread starter Thread starter dsptl
    Speed
The discussion focuses on applying the work-energy theorem to determine the speed of a 10kg block just before it hits the ground in a frictionless environment. Participants emphasize using conservation of energy principles, suggesting to equate the total potential energy at the start with the total kinetic energy just before impact. They clarify that each block's height must be accounted for individually, as they may differ, and that the total energy should be the sum of the potential and kinetic energies of all blocks. The importance of using correct equations from textbooks is highlighted, along with the suggestion to calculate acceleration using Newton's laws. The conversation ultimately aims to guide the original poster in solving the problem effectively.
dsptl
Speed Problem (Please Help!)
* A system of blocks is released from the rest. the speed of 10kg block just before it hits the ground the ground. The surface is frictionless.
http://img80.imageshack.us/img80/6199/24722704da3.jpg
Attempt:
I hv donw this way, but I am suppose to use work-kinetic energy theoreom or something to find the answer, which i hv no clue abt it...thought u guys would help me
first i found acceleration: a = g(M -m1sin45 - m2sin45)/(M+m1+m2) = 4.31 m2/s2
then used vf2 = vi2 +2ax = 0 + 2(4.31)(5) = 42.23m2/s2
and vf = 6.5m/s
but i need get this answer by Work-Kinetic theorem or something...Please HElp
Thanks in advacne
Use conservation of energy. Write an expression for the total energy just before things start moving. Then write an expression for the total energy when the block hits the ground.
our professor slightly went over it...can u please just write the expression, I can work tht out
Thanks a lot for helping
The exact equations should be in your textbook. There is (gravitational) potential energy and kinetic energy to account for.
but there r 3 blocks how do i add them together for the energy?
starting: (m1+m2+m3)gh = .5(m1+m2+m3)v*v
but I the height is not given for all the blocks...
There are two problems here.
1. The heights are all different. So you'll have to use h1, h2, and h3 for the heights of each block. Don't worry that the heights are not all given, it will work out in the end.
2. Potential and kinetic energies are not equal to each other. Instead, you add them together, to find the total energy of the 3 blocks.
Or you can simply find the acceleration of the system using Newton's laws, and then calculate the final velocity using equations of motion
