Speed relativity, Einsteins theorie
  • Thread starter Thread starter slrn
    Relativity Speed
To determine the speed required for an astronaut to reach a solar system 80 light-years away in 8 years, the Lorentz contraction formula is applied. The proper length (L0) is 80 light-years, and the time experienced by the astronaut (T0) is 8 years. By rearranging the equations, the speed can be expressed as a function of distance and time. The calculations involve solving for velocity (v) using the relationship between proper length and time dilation due to relativistic effects. Ultimately, the astronaut must travel at a significant fraction of the speed of light to achieve this journey within the specified timeframe.
slrn
astronaut has 8 years to get to a solar system that earthlings see is 80c years from earth. How fast does the astronaut have to go to get there in 8 years.
L=L0(sqrt(1-(v/c)^2)
L0/T=L/T0
L0 = 80 cyears
T0 =8 years
Hint: Express the speed in terms of distance and time.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
