Spherical EM Wave: Origin at t=0, S & S' Agree?
In summary, two frames S and S' coincide at t=0, with S' moving to the right along the positive x-axis at a relative velocity v. A spherical electromagnetic wave leaves the origin of S the moment S and S' coincide. However, according to the Lorentz transform equations, x' does not equal x and t' does not equal t. Therefore, S and S' would not agree that x' = x, and S' would not detect the wavefront in his own frame as being the same distance away from his own origin as S does in the same time.
Pezz
Consider two frames: S and S', with S' moving to the right along the positive x-axis or S at a relative velocity v. The origins of S and S' coincide at t = 0.
A spherical electromagnetic wave leaves the origin of S the moment S and S' coincide, or at t = 0.
If we consider the transformation equations for how far from the origin of each frame the wave has travelled, would S and S' agree that x' = x? In other words I mean to ask, that if the wave has traveled 2m in the x direction in S in some time, and S detects S' 1m away from the wavefront in the S frame, regardless of relative velocity S' in his own frame would detect the wavefront in his own frame also 2m away from his own origin in that same time?
If I'm understanding the question right, the answer is no.
The transformation equations in question are the Lorentz transforms. See http://en.wikipedia.org/wiki/Lorentz_transformation#Boost_in_the_x-direction for the transform equations for the situation you describe, which is called a "boost in the x direction".
We will denote the coordinates in frame S by the variables (t,x), and in the frame S' the coordinates are (t', x').
Using the transform equations from the Wikki article, note that x' does not equal x, nor does t' equal t. However ## (x^2 - c t^2) = (x'^2 - ct'^2) = 0##. For right moving waves x = ct, x = -ct, or (x+ct) = 0. If ## (x^2 - c t^2) = (x'^2 - ct'^2) = 0##. then either x=ct or x= -ct, so that equation describes a spherical wavefront which can be either left-moving or right-moving.
1. What is a spherical EM wave?
A spherical EM wave is a type of electromagnetic radiation that propagates outward in all directions from its source, creating a spherical wavefront. It consists of oscillating electric and magnetic fields that are perpendicular to each other and to the direction of propagation.
2. What do you mean by "Origin at t=0", and how does it relate to a spherical EM wave?
"Origin at t=0" refers to the point at which the spherical EM wave is generated. In other words, it is the starting point of the wave. This concept is important because it helps us understand how the wave propagates and how its properties change over time.
3. What is the significance of "S & S' Agree" in the context of a spherical EM wave?
In the context of a spherical EM wave, "S & S' Agree" means that the wave looks the same when observed from two different frames of reference. This is known as the principle of relativity and is a fundamental concept in physics. It tells us that the laws of physics are the same for all observers, regardless of their relative motion.
4. How does a spherical EM wave behave in different mediums?
A spherical EM wave behaves differently in different mediums. In a vacuum, it travels at the speed of light and does not experience any change in its properties. However, in a medium such as air or water, the wave can be refracted, reflected, or absorbed, depending on the properties of the medium.
5. Are there any real-life applications of spherical EM waves?
Yes, spherical EM waves have many real-life applications. They are used in communication systems such as radio, television, and cellular networks. They are also used in medical imaging techniques like MRI and in industrial processes such as welding and cutting. Additionally, spherical EM waves are being studied for their potential use in wireless power transmission and space exploration.
