Voltage-to-Current Converter Circuit: Simulated in OrCAD Spice
  • Thread starter Thread starter Rudinhoob
    Circuit Converter
The discussion revolves around a voltage-to-current converter circuit simulated in OrCAD Spice, where users express confusion about the current behavior when altering voltage or resistance. It is clarified that the output current should remain constant through the load resistor (RL) if the voltage and resistance are constant, but changes when these parameters are adjusted. A key point raised is the importance of ensuring the output voltage does not exceed the supply voltage, which resolved the initial issue for one user. Participants emphasize that errors in simulation results are typically due to incorrect circuit connections or misunderstandings rather than faults in the SPICE software itself. The conversation highlights the reliability of SPICE simulations compared to traditional breadboarding methods in modern circuit design.
Rudinhoob
Hi,
Here's a voltage-to-current converter circuit I simulated in OrCAD Spice. While the current is supposed to be constant through out the load, it does not seem the case with spice, when altering V or R.
Thanks.
What? OrCAD lying? Never.
Haha. Jokes apart. Your voltage to current converter is having the loading effect.
What's the loading effect?
Sorry I was too fast to say it is loading effect. Actually in this case with OPAMP loading effect won't happen. Your output current should not change with R but it should change with V.
Can you show me screenshot of the schematic or netlist?
i = V/R so it changes with V or R, not R-load.
Damnit. I was correct in the first place. It is loading effect.
http://en.wikipedia.org/wiki/Voltage_divider#Loading_effect
Which resistance are you talking about?
The grounded R.
The other resistor R(L) represents the load.
Rudinhoob said:
The grounded R.
Aha, you can say RL instead of writing R-load. Its easier to understand.
Now, you have one concept wrong here. The RL you are referring to is not the load of the circuit. Its just a resistor connected to the output of the OPAMP to limit the current coming out of it. The actual load is R which is where the current is going to and reaching ground. That is where you connect your next stage of circuits. In other words, your next stage of circuit replaces where the R is.
Thanks.
I think you misunderstood what the circuit is meant to do (and I'm also confused by the previous post!)
If V and R are constant, it keeps the current through RL constant if RL changes. (The constant current = V/R.)
If you change V or R, you get a different "constant" current through RL.
When analyzing the circuit, the i = V/R is the current through RL, which is the load, and this current is apparently independent of the RL.
Yes but that's not what SPICE is giving me, when I change RL, it changes the current.
Did you check if you hit the rails (does the output voltage of the op amp reach the supply voltage)?
Thanks for the hint! Adjusting the ohms to make sure the output voltage is less than the supply did the trick.
Also, Rudinhoob, SPICE almost never lies. If you don't understand the output of a simulation the issue is most likely:
1. You hooked up the circuit wrong. (this is almost always it)
2. You don't understand the circuit.
3. Your models are wrong.
4. You set the accuracy or step-size wrong.
Way, way down the list is SPICE is lying. I'm a professional at this stuff and I've only seen in ONE case where a simulator was making an error. And this was an accelerated matrix-solver, not a vanilla SPICE.
Seriously, "SPICE is wrong" should be the LAST assumption you make.
Yeah you are right carlgrace, I might be influenced by some analog epic, Bob Pease ;)
Hahah that famous "What's all this SPICE stuff anyway?" article! :)
That thing is so obsolete it isn't even funny.
Although the photo of Bob throwing his PC off the roof of the National Semiconductor parking lot was pretty funny.
I knew Bob (he passed away a couple of years ago) and he refuted that article years ago. He used SPICE. In fact, in a modern IC, breadboarding is MUCH more likely to lie to you than SPICE.
That only makes sense. All analog legends might had fixed Tek. 547 using breadboard while eating pizza in MIT building 20 at 3 am. But they can never ignore the convenience and accuracy of SPICE program.
