Spot Size on Moon from Earth Laser Beam
  • Thread starter Thread starter nannygreen
A laser beam directed at the moon from Earth diverges at an angle of 1.8 x 10^-5 radians, resulting in a spot size calculation. Using the formula for angular diameter, the spot size can be determined by converting the angle to degrees and applying the distance to the moon. The calculation shows that the spot size on the moon is approximately 391.56 km. This value remains consistent whether considering the moon's curvature or treating it as flat due to the scale involved. The discussion emphasizes the simplicity of the calculation despite the moon's radius not being provided.
nannygreen
I need some help on how to start this problem and I think I can work it out.
A laser beam is directed at the moon 380,000 km from earth. The beam diverges at an angle of 1.8 x 10-5 rad. How large a spot will it make on the moon?
That would be you equation for finding the length of an arc.
s=r\theta
Technically, that gives you the diameter on a flat moon.
You'd then have to figure out how big of an angle that is based on the Moon's radius and use your equation of the length of an arc once again. Considering the size of your spot as compared to the radius of the Moon (1738.1 km), it's not worth it (which is why the radius of the moon wasn't given). For the number of significant digits given, accounting for the curvature of the Moon winds up being the same as for a flat moon.
To solve this problem, we can use the formula for angular diameter:
Angular diameter = Spot size / Distance
First, we need to convert the given angle in radians to degrees:
1.8 x 10^-5 rad = 1.8 x 10^-5 x (180/π)° = 0.0010324°
Next, we can plug in the values into the formula:
0.0010324° = Spot size / 380,000 km
Solving for the spot size, we get:
Spot size = 0.0010324° x 380,000 km = 391.56 km
Therefore, the spot size on the moon from the earth laser beam will be approximately 391.56 km.
