Spring Constants/Work And Energy
  • Thread starter Thread starter eann595
    Energy Spring
The discussion centers on two physics problems involving spring constants and work-energy principles. The first problem involves a 15 kg mass attached to a spring with a force constant of 500 N/m, requiring the calculation of its velocity after falling 0.30 m. The second problem pertains to a 0.75 kg sphere dropped through liquid, where participants need to determine the work done by friction and the average frictional force after falling 2.0 m with a velocity of 2.5 m/s. Participants express confusion about the calculations, particularly regarding the relationship between work, kinetic energy, and frictional forces. The thread emphasizes the need to analyze mechanical energy changes to solve these problems effectively.
eann595
I'm having a bit of a problem with these homework questions, if anyone could help out that would be great!
1. A 15 kg mass is attached to a massless spring by a light string that passes over a frictionless pulley. The spring has a force constant k= 500 N/m and is unstretched when the mass is relased. What is the velocity when it has fallen a distance of .30 m?
2. A 0.75 kg sphere is dropped through a tall column of liquid. When the sphere has fallen a distance of 2.0 m, it is observed to have a velocity of 2.5 m/s
a. how much work was done by the frictional force exerted on the sphere by the liquid?
b. what is the average force of friction during the displacement of 2.0 m?
I am completely stumped, =( please help!
PF usually asks that you show an attempt first.
In both problems, analyze what happens to the mechanical energy.
I'm struggling with the same questions as eann595, but I attempted to work them out so please help!:
1.) a 0.75 kg sphere is dropped through a tall column of liquid. When the sphere has fallen a distance of 2.0 m, it is observed to have a velocity of 2.5 m/s.
a.) How much work was done by the frictional force exerted on the sphere by the
liquid?
* I need the net work of friction, so I started with Wnet(Fr) = change in KE = ma.
* Fr x cos(180) x d = 1/2mv^2 = ma.
* Fr x -1 x 2.0m = 1/2(0.75kg)(2.5m/s)^2 = (0.75kg)(a)
* -2.0m x Fr = 2.34 kg x m squared/sec squared = (0.75)(a)
I have a feeling that b/c acceleration is not given, it equals g aka 9.8 m/s^2 (??) Am I on the right track with this problem?
b.) What is the average force of friction during the displacement of 2.0m?
This one I think I need to know the answer to letter a.) to solve.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
