Calculating Initial Energy of a Spring-Connected Mass
In summary: Set up the conservation of momentum equation and the conservation of energy equation. You have two unknowns, and two equations relating those two unknowns.Momentum conservation applying0.1 v = 3mApplying energy balance1/2 * 0.1v2 = 9/2 m Yeah v = 3m/sBut as I say, how we are assuming elastic collision?Well, they really should have specified. They obviously want you to treat the collision as perfectly elastic, because they don't mention any energy being lost due to non-conservative forces (such as friction). But really, I guess we don't know.
Raghav Gupta
1,011
76
A block of mass m = 0.1 kg is connected to a spring of unknown spring constant k. It is compressed to a distance x from its equilibrium position and released from rest.
After approaching half the distance (x/2) from equilibrium position, it hits another block and comes to rest momentarily, while the other block moves with a velocity 3 m/s. The total initial energy of the spring is:
1.5 J
0.6 J
0.3 J
0.8 J
Spring potential energy is 1/2 kx2
In this question we have to do basically energy balance
Isn't this question wrong?
We should be given other block mass and told that it is an elastic collision?
Why don't you post your work so we can see what you have so far. It is solvable.
AlephNumbers said:
Why don't you post your work so we can see what you have so far. Even if it were wrong, it would be a good exercise.
Initial energy = 1/2 kx2
At x/2 distance,
1/2 kx2 = 1/2 kx2/4 + 1/2 mv2
Now we know the mass of the block which is colliding but don't know velocity at that instant of colliding.
If we have been told that other block has same mass and it is an elastic collision then v could be 3m/s ?
If the first block stops moving after colliding with the second block, and the second block continues forward with a velocity, then I think it is safe to assume an elastic collision. Although it would have been nice if they had specified that it was an elastic collision in the problem statement.
Your work looks good so far. What do you know about elastic collisions?
In elastic collisions momentum and energy are balanced initially and finally.
If two blocks should have same velocity one transferring other, then masses should be same.
But they have not given that.
Bingo!
0.1 v = 3m
1/2 * 0.1v2 = 9/2 m
Yeah v = 3m/s
Well, they really should have specified. They obviously want you to treat the collision as perfectly elastic, because they don't mention any energy being lost due to non-conservative forces (such as friction). But really, I guess we don't know. It is the fault of whoever made this question.
Likes Raghav Gupta
Thanks.
1. How do you calculate the initial energy of a spring-connected mass?
To calculate the initial energy of a spring-connected mass, you can use the formula E = 1/2 kx^2, where E is the initial energy, k is the spring constant, and x is the displacement of the mass from its equilibrium position.
2. What is the unit of measurement for initial energy?
The unit of measurement for initial energy is joules (J).
3. Can the initial energy of a spring-connected mass be negative?
Yes, the initial energy of a spring-connected mass can be negative if the mass is released from a position where the spring is stretched or compressed in the opposite direction.
4. How does the initial energy of a spring-connected mass change with the spring constant?
The initial energy of a spring-connected mass is directly proportional to the square of the spring constant. This means that as the spring constant increases, the initial energy also increases.
5. Can you calculate the initial energy of a spring-connected mass if you only know the mass and the displacement?
Yes, you can calculate the initial energy of a spring-connected mass if you know the mass and the displacement by using the formula E = 1/2 mv^2, where m is the mass and v is the velocity of the mass. However, this method assumes that the initial velocity of the mass is zero.
