Understanding Spring Forces: Net Force and Spring Scale Readings
  • Thread starter Thread starter turdferguson
    Forces Spring
In a scenario with a spring scale on a frictionless surface, two equal and opposite horizontal forces of 10 N are applied, resulting in a net force of 0 N, not 20 N. The spring scale measures the tension in the spring, which reflects the force applied to compress or stretch it, resulting in a reading of 10 N. The discussion emphasizes that forces are vectors, and direction is crucial in determining net force. It is clarified that a spring cannot be compressed or stretched by applying force to only one end. Understanding these principles is essential for accurately interpreting spring scale readings.
turdferguson
I just want to quickly check something. A spring scale lies horizontally on a frictionless surface. A horizontal force of 10 N to the right is applied to the top of the scale and another horizontal force of 10 N to the left is applied to the bottom.
1. The net force is ___ obviously 20 N
2. The reading on the spring scale will read ___ I am inclined to think that it would only be 10 N. The situation would be the same if the spring was attached to a wall. Am I right? Afterall, they wouldn't ask the same question twice
This is incorrect. Rethink this: what's the net force on the spring scale? Recall that forces are vectors--direction counts.
Yes, you are right. The spring scale reads the tension in the spring, which is 10 N.
I saw this question before and it got me thinking, I do not really understand it. The spring is being compressed by two forces. Now if the reading is based on the fact that two equal and opposite forces will always act on the spring and then it takes the size of these forces that is okay.
I still cannot seem to get over the fact that there are two 10N forces compressing the spring.
If you can figure out a way to compress (or stretch) a spring by pushing (or pulling) on one end only, I'd like to see it. (Won't happen!)
The spring scale measures the degree of compression (or elongation) which is proportional to the compression force (or stretching force).
That's actually what I was trying to do :D
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
