System Dynamics: A Qualitative Understanding
The discussion centers on a spring-mass system analyzed qualitatively without heavy reliance on mathematical dynamics. The system is described as having motion restricted to the x-y plane, with initial conditions allowing for perturbations from a resting position. The participant identifies three differential equations governing the mass's motion along both axes and the system's energy. Questions arise regarding the stability of the system when equations are decoupled and whether periodic trajectories exist when equations are coupled. The participant also expresses confusion about the motion's restriction to the x-y plane, suggesting it should only be confined to the y-axis due to the forces at play.
Johnrobjr
I did read some of the posts on the topic. However, I just want to check my qualitative understanding without employing too much mathematical dynamics. If anyone has some feedback, this would be much appreciated.
The System.
A spring hangs vertically. There is a mass attached to it.
Assumptions
The motion is restricted to act in the x-y plane. There is no friction or damping.
Initial Conditions
The mass can be perturbed from its resting position (the origin, -y axis parallel to the gravitational force).
My Understanding
There are three differential equations:
one for the mass moving along the y-axis.
And, one the mass moving along the x-axis.
Also, the is one for the energy of the system.
Most generally, the equations describing the motion in the plane are coupled, and a closed form solution is not possible. However, if the spring is stretched only so that it operates in the linear region, and the pendulum is displaced only so that it is operating in the linear region...then the equations are decoupled and a solution is possible.
My question is under those initial conditions where the equations are decoupled, will the system be stable, assuming no friction or damping? I think it will degenerate, but I am not sure why.
Also, if the system is operating so that the equations are coupled then many trajectories are possible (perhaps infinite). Is this true?
It the system operates so that the equations are coupled then are there periodic trajectories that remain stable or will they always evolve to others with time?
The system has no external energy and the internal energy is balanced (gravity vs spring).
If there is no friction or damping, once the mass is stretched, it will keep oscillating forever.
Time has no role here, once you begin this oscillating there is no stopping it without an external force.
I still cannot understand how the motion is restricted to the x-y plane, it should only be restricted to the y plane along which the only two forces are (gravity and spring)
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
