Maximizing Potential Energy in a Falling Mass-Spring System
The discussion revolves around solving a physics problem involving a 10-g mass attached to a vertical spring with a spring constant of 49 N/m. The primary focus is on applying the conservation of energy principle to determine the maximum speed of the mass and the distance it drops before momentarily coming to rest. Participants suggest using the equation for kinetic energy (KE), gravitational potential energy (GPE), and spring potential energy (SPE) to derive the necessary relationships. Key advice includes isolating the kinetic energy in the equation and finding the value of y that maximizes it, with the understanding that this value will be negative as it measures displacement from the unstressed position. The conversation highlights the importance of correctly accounting for all forms of energy in the system.
Rhaen
Hello all, I am looking for some assistance with a physics problem that I have for my physics class. Any help would be greatly appreciated because I have no idea where to start. Thank you all ahead of time for your help.
The problem is:
A 10-g mass is attached to the end of an unstressed, light,
vertical spring (k = 49 N/m) and then dropped. Answer the
following questions by considering the potential energy due
to the spring plus the potential energy due to gravity, i.e.
measure distances from the equilibrium position of the spring
with no mass attached. (a) What is the maximum speed of the
falling mass? (b) How far does the mass drop before coming
to rest momentarily? (c) Repeat (a) and (b), but answer the
questions by considering the potential energy of the spring
with the mass attached, i.e. measure distances from the
equilibrium position of the spring with the mass attached.
I don't even know how to start with the problem so any help would be most appreciated.
-Rhaen-
Ok so far all I have been thinking I could do with part a is this...
(a)
(1/2)mv^2 + mg(y_1-y_2) = (1/2)mv^2 + mg(y_1-y_2)
This comes from the equation K_1 + U_1 = K_2 + U_2
I don't know if I am missing something in that equation though. I know that there will be cancelations, I think the U_2 and K_1 possibly, but I'm not sure exactly how I would calculate the velocity out of that equation. Thank you for any light you can shine on this.
-Rhaen-
Don't forget spring potential energy: 1/2 k y^2
Now apply conservation of energy:
KE_1 + GPE_1 + SPE_1 = KE_2 + GPE_2 + SPE_2
Hint: Given the initial speed and your reference point for measure PE, all the terms on the left are zero.
So then the equation qould go:
0 = (1/2)mv^2 + mg(y_1-y_2) + (1/2)ky^2
0 = (.1kg)v^2 + (.2kg)(9.8)(y_1-y_2) + (49)y^2
If that is the case then how would I calculate the y distance so that I can have only the variable for velocity remaining? Thank you for your time.
-Rhaen-
I would write the equation like this:
0 = (1/2)mv^2 + mgy + (1/2)ky^2
You are measuring the potential energy from the y=0 (unstretched) point. Now isolate the KE to one side, giving KE as a function of y. The find what value of y maximizes the KE. (The answer will be some negative value for y.)
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
