Calculating Spring Constant for Car Suspension | 1300 kg Vehicle Weight
  • Thread starter Thread starter synchronous
    Car Springs
The discussion revolves around calculating the spring constant for a car's suspension system given a vehicle weight of 1300 kg and an oscillation frequency of 3 Hz. The springs are treated as identical and arranged in parallel, leading to a total spring constant expressed as 4k. The initial approach used the wrong formula for angular frequency, leading to an incorrect calculation. Correcting the formula to w = 2πf allows for the accurate determination of the spring constant, which is found to be 2925 N/m. The conversation highlights the importance of using the correct equations in physics problems.
synchronous
An automobile can be considered to be mounted on four identical springs as far as vertical oscillations are concerned. The springs of a certain car are adjusted so that the oscillations have a frequency of 3 Hz.
(a) What is the spring constant of each spring if the mass of the car is 1300 kg and the weight is evenly distributed over the springs?
w = (k/m)^(1/2)
k(total) = k1 + k2 + k3 + k4 = 4k
Since the springs are arranged in a parallel fashion, I can add their individual spring constants for an overall constant. Since the springs are identical, I can rewrite the sum of constants as 4k. Then, using the first equation listed above I have:
3 = (4k/1300)^(1/2) and solving for k I found the solution to be 2925 N/m. What's wrong with my approach?
w =/= f
w = 2πf
That's the only thing I can spot that's wrong. See if that gets you to the text-book's answer.
You're welcome. ^^
Dumb mistake on my part...thanks for the help...you're right on the money!
