Square numbers probability help
The discussion revolves around solving a probability problem involving blue and red marbles. The user correctly identifies the probability of blue marbles as 7/(k+7) but struggles with the equation for part (d). Another participant confirms the user's probability and suggests considering additional scenarios where the two girls could pick different colored marbles. They guide the user to simplify and cross-multiply the equation, highlighting the potential emergence of a k^2 term. The conversation emphasizes the importance of exploring all outcomes in probability calculations.
david18
Hi, I am trying to solve a question on a past paper; here is one that is very similar to it- http://www.gcsemathspastpapers.com/images/p5j04q19.htm
Im presuming the probability of blue marbles is 7/(k+7)
On part (d) would i have to do something like:
7/(k+7) x k/(k+7) = 4/9 ?
Ive tried the above equation but it doesn't seem to work out seeing as it doesn't give me any square numbers as the LCM becomes 9(k+7)
any help would be much appreciated.
You're correct for the probability of blue.
For the second part, you're really close. You have the probability that the first girl gets blue and the 2nd girl gets red. Isn't there something else that could happen such that they still have different colors? (Then, simplify and cross multiply)
edit:
You have \frac{7}{k+7}*\frac{k}{k+7} = \frac{4}{9}
= \frac{7k}{(k+7)^2}=\frac{4}{9}
Are you sure you don't end up with a k^2 term in there?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
