Square Rooted varible by itself (/x)
  • Thread starter Thread starter bushman91
    Square
To isolate "d" in the equation involving square roots, the discussion clarifies that the correct interpretation of the square root symbol is crucial. The initial equation 1050 = 2700 / sqrt(d) can be rearranged to d = (1050^2) / (2700^2), resulting in d = 49/324. Additionally, for the equation 0.388 = /sqrt(d), squaring both sides yields d = 0.15054. The conversation emphasizes the importance of correctly interpreting the equations in the context of string vibrations at specified frequencies.
bushman91
Such a simple problem that I am stuck on...
1050=2700 /d
0.388=/d
how do i get "d" by itself? ( the "/" is square root not divide)
edit: is "D" diameter or distance... one is "d" and other is "D"
1050=2700*/sqrt(d)
1050^2=2700^2*d
d=1050^2/2700^2 =49/324
#2)
.388=/sqrt(d)
.388^2=d
d = .15054
Square both sides
thanks guys, i was thinking that, but in the question it was dealing with string vibrations were 1050hz and 2700hz and 1mm..
original question:
(1050)(/sqrt 1)=(2700)(/sqrt D)
got to that last part and forgot what to do so i did it like this:
if 1mm equals 1050hz - then 1/1050 would equal how many mm's per hz
it was 0.000952mm/1hz
so then 0.000952mm/1hz * 2700hz would equal my answer of 2.57mm but i guess its not right...
thanks again
original question:
Are those slashes part of the root sign ? 1050\sqrt{1}= 2700\sqrt{D} ? If so, just divide both sides by 2700.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
