Squeeze theorem trig question. Please and thanks
nukeman
Ok, you can see the question and how far I got from the image.
Lim x--> infinity
So, let's take the LEFT side: how does 3x-1 / x turn into just 3?
I know the answer is 3, but from where you can see in the pic, that is where I get stuck, and don't know how to go on from there.
THanks!
hi nukeman! :smile:
the 1 becomes insignificant compared to 3x as x -> ∞, so that leaves you with 3x/x, which is 3
alternatively: (3x-1)/x = 3 - 1/x, and 1/x -> 0 as x -> ∞, so 3 - 1/x -> 3 :wink:
How does the 1 become insignificant? That is what I am having trouble understanding. :(
Thanks for the reply :)
because the 3x becomes 30000 then 30000000000 then 300000000000000 and so on, and the tiddly little 1 doesn't matter much any more :redface:
Lim x--> infinity
THanks!
It generally helps us, if you state the problem you're trying to solve.
In this case it appears to be:
Find \displaystyle \lim_{x\,\to\,\infty} \frac{3x+\cos^2(100x)}{x}\ .​
By the way: 0\le \cos^2(100x)\le 1\ .
why is it 0≤ instead of -1?
I meant to ask you !
limit as x -> infinity of [ 3x + cos^{2}(100x)] / x
I thought it would -1 ≤ cos^2(100x) ≤ 1
since a cos has amplitude of -1 and 1 ?
Right regarding cos(x).
How about cos2(x)? Is that ever negative?
wow, how did I NOT know that! :(
Ok thanks... I got that now.
So the left side would be 3x/x correct? so, then I would put each term over x, leaving 3 and 1 (3 * 1 = 3) correct?
Please write the expression that you're trying to describe .
