How Do You Calculate Wave Properties in a String Experiment?
To calculate wave properties in a string experiment, the wavelength is determined by averaging the lengths of loops, leading to a value of approximately 96.1 mm. The velocity is calculated using the formula v = fλ, resulting in about 4.807 m/s, with uncertainty derived from the wavelength's uncertainty. Tension is calculated using T = mg, yielding a value of 1.96 N, with uncertainty based on the mass measurement. Uncertainty in measurements should be derived from the individual uncertainties rather than simply taking the range of values. Proper application of uncertainty calculations is essential for accurate results in wave property experiments.
charmedbeauty
During the experiment you will be collecting data similar to that in the table below. The experimental set up is the same as that described in your lab manual. Complete this table. Assume that the frequency is 50 Hz, and is known accurately.
this is the data given.
1 Loop (mm) =48.9 +/- 1.5
2 Loops (mm)=96.4 +/- 2.0
3 Loops (mm)=141.3 +/- 2.0
Hanging mass= 200 +/- 5 (g)
frequency = 50 Hz
Find
1)Wavelength with uncertainty (mm)
2)velocity m/s with uncertainty
3)Tension (N) with uncertainty
to find the wavelength
im guessing I should find the average length within the loops.
so...
48.9 + 96.4/2 + 141.3/3 =144.2
144.2/3 = 48.1
λ= 2* (48.1)
λ= 96.1 (is this right??) →how would I find the uncertainty? is it just find λ with the largest value for the length and subtract λ with the smallest length and divide by 2?
v=fλ
v= 50(0.0961)
v= 4.807 m/s (is this right) → is the uncertainty just the uncertainty in λ?
T = mg
T = 0.2 (9.8)
T= 1.96N and uncertainty in T is I'm guessing the uncertainty in mass = 0.005 are these the right units (kg).
Thanks.
as good as any
that what you calculated
No - you derive it from the uncertainties in the individual measurements.
eg. if x is the measurement and s is the uncertainty then the uncertainty on ax is as (where a is a constant) and so on. You'll have these rules written down somewhere.
I think that actually answers all you questions.
