Shape of Standing Wave at Maximum Kinetic Energy
  • Thread starter knowNothing23
  • Tags
    Shape
In summary: The wave function for a string vibrating in its third harmonic is a cosine function. When x=1, the wave function is y(x,1)=0.707cos(100x). At other points, the wave function is different, but always has a maximum at time=0. The wave shape is a line at these times.
knowNothing23
35
What is the shape of the string at time=0?
This is my wave:
y(x,t)=(0.03)sin( (3π/4)x)cos(200πT)
I assume that x=vt and replace in sin. Then sin(0)=0 and then the shape of the string is a line.
Is this correct?
This is a standing wave, a two-variable function of the independent variables x and t. y(x,t) is the displacement from horizontal of a point at x distance from one end. This displacement changes with time as a cosine function, cos(200πt). Substitute t=0 and see how the string looks like.
ehild
Cosine of 0 is 1. Then, y(x,t)=Asin(Kx)
There's no information of x. I thought that the amplitude or displacement was Asin(Kx)
I don't know, what's the shape of the Standing wave.
So, I guess that at time 0, there's no movement and therefore a line?
At t=0, the shape of the wave is y(x,0)=0.03sin((3pi/4)x) You know the sine function, do you not? Try to plot the function in terms of x. At what value of x is it zero? Where is maximum and minimum? ehild
I know very little about the sine function, but I've seen it. I tried to plot sine with a changing x from 0 to 5.
I noticed that Y gives me 0 for every case. Then, I assume that it's always zero and therefore a line.
Is there a way to know this behavior without having to plot it?
Thank you.
How did you get zero for all x? Note that the argument of the sine is in radians. Set your calculator to "rad" .
If x=1 3pi/4 =2.356. Set your calculator to rad and input sin(2.356). It is 0.707.
You can also transform the argument to angles. 3pi/4 x =135x degrees. If x=1, you have sin(135).
The sine function varies between -1 and 1. The amplitude of your wave is 0.03, so it changes between -0.03 and 0.03.
See this: http://www.univie.ac.at/future.media/moe/galerie/fun2/fun2.html#sincostan and use the Applets
ehild
I got ( 0.707), but I rounded it up and in some cases I got ( -0. something else), but did the same.
Why do you infer that x is 1?
If the wave changes from -0.03 to 0.03, can I say that it is a line or looks like a line?
Thank you ehild.
Thank you ehild.
X=1 is just an example to show that y is not zero.
Values between -0.03 and 0.03 are not too small - with respect to what?? The string is not a straight line, and it does not look a straight line. You do not know the unit of the amplitude. If it is in meters, 0.03m is 3 cm and it is definitely not zero.
Such standing waves appear in musical instruments. There are standing waves on the string of a violin, for example. You hear the sound even when the amplitude is a few mm.
ehild
This is the whole problem:
•• A 2.00-m-long string fixed at one end and free at the other (the free
end is fastened to the end of a long, light thread) is vibrating in its third harmonic
with a maximum amplitude of 3.00 cm and a frequency 100 Hz. (a) Write the
wave function for this vibration. (b) Write a function for the kinetic energy of a
segment of the string of length dx, at a point a distance x from the fixed end, as a
function of time t. At what times is this kinetic energy maximum? What is the
shape of the string at these times? (c) Find the maximum kinetic energy of the
string by integrating your expression for Part (b) over the total length of the
string.
I forgot to mentioned that the maximum kinetic energy happens at time equal 0. Does this make the wave a line? Why?
What is a standing wave?
A standing wave is a type of wave pattern that occurs when two waves of equal amplitude and frequency travel in opposite directions through a medium and interfere with each other. This results in a stationary pattern of nodes and antinodes.
How is the shape of a standing wave determined?
The shape of a standing wave is determined by the boundary conditions of the medium it is traveling through. These include the length of the medium, the speed of the waves, and the nature of the medium itself.
What is the difference between a standing wave and a traveling wave?
A standing wave does not appear to move through a medium, while a traveling wave moves through a medium. Additionally, a standing wave is created by the interference of two waves, while a traveling wave is created by a single wave source.
Can the shape of a standing wave change?
Yes, the shape of a standing wave can change if the boundary conditions of the medium change. For example, if the length of the medium is altered, the nodes and antinodes of the standing wave will shift accordingly.
What are the applications of standing waves?
Standing waves have various applications in science and technology, including in musical instruments, electromagnetic fields, and particle accelerators. They can also be used to study the properties of different materials and the behavior of waves in different mediums.
