Start capacitors on 2 phase equipment
Issues with a replacement chiller unit requiring 230VAC single phase are discussed, particularly regarding its operation on a 2-phase 110VAC supply. The failure of the compressor to start consistently, despite running previously on a similar setup, raises questions about the adequacy of the starter capacitor. It is noted that the new motor may not handle the lower voltage effectively, leading to higher current demands that the existing capacitor cannot meet. The discussion emphasizes the importance of understanding phase angles and suggests that using a larger start capacitor or a "hard start" kit could resolve the starting issues. Overall, the electrical supply configuration and component specifications are critical to ensuring proper motor function.
tonyole
Hi there. So here goes.
I have been having issues with a replacement chiller unit that requires 230VAC single phase.
An identical unit was running on 2 phases of a 110VAC 3 phase supply. I had a start capactior fail in this unit. When I connected the replacement unit, the compressor failed to kick on however it started when bumped with my fist. After kicking off however, the compressor would not always kick back on when required.
So... Since the power supply I'm using to "mimic" a single phase 230VAC supply is ACTUALLY a 2 phase 110VAC (2 of 3 phases) ie. not 180° opposed but 120° then 240°, does this mean that with regard to starting capacitors, polarity becomes an issue?
I am aware that the resultant voltage is 208VAC, however the original unit has run on this supply for a number of years without issue.
Thanks for any insight.
T
The starter capacitor with the new motor may be insufficient to pass the necessary starting current at the lower voltage.
Induction motors do not like low voltages, as they then draw a high current.
The starter capacitor has less voltage and a higher current demand. It will be too small.
New motors are built closer to the minimum spec. Old motors are more tolerant to abuse.
Are there two or three power wires going into the motor ?
A 208/120 system
is 120 single phase when connect from phase to neutral
and when you connect with just two wires from phase to phase it's 208 but still single phase
so your assumption about phase angle
Since the power supply I'm using to "mimic" a single phase 230VAC supply is ACTUALLY a 2 phase 110VAC (2 of 3 phases) ie. not 180° opposed but 120° then 240°, ...
is not correct unless all three phases, not just two of them, are carried to the motor.
Draw your phasor triangle.
Baluncore seems on right track. A bigger start capacitor may help. Electrical supply houses sell "hard start" kits for residential airconditioners - basically just more starting capacitance.
Thanks guys. I appreciate the input.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
