Static Electricity corrupting electrical equipment
Static electricity is causing significant issues with networked alarm panels in a specific room, leading to component failures and electrical shocks upon contact with metal surfaces. The dry winter conditions exacerbate the problem, and the static shock can disrupt the panel's CPU through connected cables. Suggestions include checking ground connections for continuity and ensuring a common ground for RS-485 devices to minimize noise. The type of flooring in the room may also contribute to the static buildup, and testing electrical outlets for proper wiring is recommended. Considering static-proof carpet for the equipment room could be a beneficial long-term solution.
p.daly
I need help. I am installing new networked alarm panels throughout a building. There is a room where one panel is and that panel is continually having components fail. While in this room it is also very common for me to receive a static shock when coming in contact with any metal. I realize that the dry winter adds to this but it has gotten so bad that the shock will travel through a metal table, through my computer, travel through my 485 connection cable and shut down my panel's CPU. We have quickly ruled out bad components and now are trying to come up with an environmental reason. Can anyone offer some help?
Might check continuity on ground connections.
+1 on Bystander's ground check suggestion. Remember that RS-485 requires a common ground (without much noise) for all devices connected to the network, so having good ground continuity is important. Are there any large sources of ground noise in this installation (like elevator motors, or other large motors)?
What is the floor like in this room where you keep getting shocks? Is it carpet or tile or other? Is it the same as the other rooms?
Have you tested the electrical outlets with a simple electrical tester to be sure that power is wired correctly in all the rooms?
http://www.electricalbasics.com/resize/Shared/images/electrical-testers/receptacle-tester-3-wire-EBTT-17-RT-CA-med.jpg?
That little outlet checker Berkeman shows is available at Walmart around six bucks - every homeowner should have one.
Your architect should have put static-proof carpet in an electrical equipment room, i would think. It has a few carbon fibers mixed into provide minimal conductivity. Worth an inquiry.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
