Will Box Y Remain in Equilibrium?
In summary, the three forces on Box X are the horizontal reaction force at B, the weight, and the reaction force from the ground. The first two forces obviously go through the center of mass, but the third force (which is mg down and 71 N horizontally) also goes through the centre of mass.
aerograce
64
A 8-kg homogeneous box X is resting against another 20-kg homogeneous box Y at
an angle such that its diagonal BC is horizontal as shown in Figure Q1. The angle
of static friction between box X and the floor is 45° and that between box Y and the
floor is 30°. Treat the contact surface between the two boxes as smooth. For
practical simplicity, use g = 10 m/s2.
Figure: View the attachment
(a) Determine whether box X is in equilibrium.
(3 marks)
(b) Determine whether box Y is in equilibrium with respect to sliding along the floor
and rotation about the corner A.
(4 marks)
[itex]\mu[/itex]=[itex]\frac{F}{N}[/itex];
Tan[itex]\alpha[/itex]=[itex]\mu[/itex]
Solving for Question b:
Identify that Box X is a three force body, and if it has to reach equilibrium state, the three forces have to pass through the center of mass. Draw a reaction force R(A) from the bottom of box X to its center of mass. Based on calculation, the angle formed by the R(A) with respect to the ground is 48.2°, which is more than the angle of static friction, and hence Box X is not equilibrium.
My problem is that, when I went to analyze Box Y, I cannot get sufficient values to analyse it as Box X is not at equilibrium and hence the normal contact force between them cannot be calculated.
Any thoughts? Thank you so much!
hi aerograce! :smile:
isn't it the other way round? :confused:
if the angle from the ground was 90°, that would be ok wouldn't it? :wink:
Hello! Could you attempt this problem? I recalculate my forces and found box X still not in equilibrium. The required minimum angle of friction is 53.2 degrees, which is more than angle of the static friction provided. Hence box X will not be in equilibrium.
My friend looks at this problem another way:
He takes moments of Box X about the point where it touches the ground, which gives him the reaction forces between two boxes. And this reaction force is 71N, which is less than the maximum static friction here(80N), hence it is in equilibrium. And my question is, if reaction force is 71N, the static friction force will be 71N as well. And the three forces will definitely not converge at one single point(according to geometry).
Sorry I am very confused now and I am looking for your help:) Thanks a million!
hello aerograce! :smile:
yes they do converge
the three forces are the horizontal reaction force at B, the weight, and the reaction force from the ground
the first two forces obviously go through the centre of mass
the third force (which is mg down and 71 N horizontally) also goes through the centre of mass :wink:
Likes 1 person
I would suggest looking at the forces acting on Box Y individually. The normal force between Box Y and the floor can be calculated using the weight of Box Y and the angle of static friction between Box Y and the floor. This normal force can then be used to calculate the maximum possible frictional force between Box Y and the floor using the equation \mu=\frac{F}{N}. If this maximum frictional force is greater than the force acting on Box Y due to Box X, then Box Y is in equilibrium. However, if the maximum frictional force is less than the force acting on Box Y due to Box X, then Box Y is not in equilibrium and will experience sliding and/or rotation. This analysis can be repeated for different angles of rotation and the maximum frictional force can be compared to the force acting on Box Y due to Box X to determine the range of angles at which Box Y will be in equilibrium.
What is static friction analysis?
Static friction analysis is a scientific method used to study the forces involved in objects that are not in motion. It involves measuring the amount of resistance between two surfaces that are in contact with each other but not sliding against one another.
Why is static friction important?
Static friction is important because it helps us understand the forces that keep objects in place and prevent them from slipping or sliding. It also plays a crucial role in designing and engineering structures and machines to ensure their stability and safety.
How is static friction measured?
Static friction is measured using a force gauge or a scale. The object in question is placed on a flat surface, and a small amount of force is applied to it in the direction of motion. The amount of force required to overcome the static friction and start the object's motion is then measured.
What factors affect static friction?
The amount of static friction between two surfaces is affected by several factors, including the nature of the surfaces, the amount of force applied, and the roughness of the surfaces. Additionally, the coefficient of friction, which is a measure of the surfaces' grip, also plays a significant role in determining the amount of static friction.
How is static friction different from kinetic friction?
Static friction is the resistance between two surfaces that are not moving relative to each other, while kinetic friction is the resistance between surfaces that are sliding or moving against each other. The amount of static friction is typically greater than kinetic friction, as it takes more force to overcome the initial resistance and start the motion of an object.
