Calculate Time to Slow Down w/Static Friction on I-79 Exit 147A
To calculate the minimum time needed to slow down from 65 mph to 0 mph without a box sliding off the seat, the coefficient of static friction between the box and the seat is essential. The discussion emphasizes the importance of knowing this coefficient, as it directly impacts the acceleration required to prevent sliding. Participants suggest using Newton's second law and drawing a free body diagram (FBD) of the box to analyze the forces involved. Without the static friction coefficient, the solution will need to be expressed as a function of that variable. Understanding these dynamics is crucial for ensuring the fragile objects remain secure during deceleration.
courtney1121
A box full of fragile objects is on the back seat of your car. You are driving at 65 mph (29 m/s) on I-79. As you get off at exit 147A for Meadville, you must slow down to 0 mph. Estimate the minimum amount of time should you take to slow down (based on the appropriate acceleration) without the box sliding off the seat onto the floor on the car.
any thoughts on where to start?
we got acceleration due to gravity and velocity. We will have acceleration going in the opposite direction of motion.
You are missing some data. The problem cannot be solved unless you know the coefficient of static friction between the box and the seat. Was this info given? Otherwise, the time will have to be expresed as a function of the static friction coefficient. For starters, draw a FBD of the box and apply Newton's 2nd law.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
