Measuring Static Resistance of Current/Voltage Graph
  • Thread starter Thread starter headshrinker
    Resistance Static
To measure static resistance from a current/voltage graph, take the voltage at any point and divide it by the current if the graph is linear. For curved graphs, use a small increment in voltage and divide it by the corresponding small change in current to find dynamic impedance. However, to obtain static resistance, simply divide the absolute value of voltage by the absolute value of current. This method provides a clear distinction between static and dynamic resistance measurements. Understanding these concepts is essential for accurate electrical analysis.
headshrinker
Hi, how do i measure the statics resistance of a current/voltage graph and not the dynamic resistance?
thanks!
If you have a straight line graph, they are the same. You just take the voltage at any point and divide it by the current.
If the graph is curved, you can take a small increment in voltage and divide that by a corresponding small change in current. This gives you the dynamic impedance.
At the same point you could just take the absolute value of the voltage and divide it by the absolute value of the current and get the resistance. This is the static resistance.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
