How Do You Calculate Reaction Forces in Static Equilibrium?
To calculate the reaction forces in static equilibrium, the equations of equilibrium are applied: the sum of horizontal forces (Fx) and vertical forces (Fy) must equal zero, along with the sum of moments about a point. The calculations show that R3 is determined to be 70kN, leading to R1 and R2 both being 21kN. The direction of moments is confirmed by the signs assigned to the forces, with anticlockwise moments considered positive. The solution is verified by checking moments about different points, ensuring the equilibrium conditions are satisfied.
Kasthuri
Question: The plate shown, picture is attached, is subjected to force F and 3 reaction forces R1 R2 R3. Find R1
equations of equilibrium:
sum of Fx = 0
sum of Fy = 0
sum of moment about point O = 0
sum of Fx = 0: (going right is positive)
-R1 - R2 + 3/5 R3 = 0
sum of Fy = 0: (going up is positive)
-56kN + 4/5 R3 = 0
so, R3 = 70kN
sum of moment about point O = 0 (going anticlockwise is positive)
R1 x (0.11m) - R2 x (0.11m) = 0
so, R1 = R2
therefore, R1 = R2 = 21kN
I am unsure of whether I have done this question correctly, in particular the moment about O.
Also, how do you figure out which direction the moment is in (anticlockwise/clockwise). As in, I took R1 x 0.11m as positive due to anticlockwise and
R2 x 0.11m as negative due to clockwise moment.
is this correct?
Thanks for any help you can offer!
R3=70Kn appears correct.
As for the moment...
R1*110 + (-R2*110) = 0
So
R1 = R2
Both same sign
Horizontally, if left is positive...
-R3*3/5 + R1 + R2 = 0
-R3*3/5 + R1 + R1 = 0
-R3*3/5 + 2R1 = 0
R1 = R3*3/(5*2)
= 21kN
which is a +ve number so to the left.
R1 = R2
so R2 also to the left.
Thank you!
To check whether you are correct, just take moments about any other point. The sum should be zero.
