Statics Problem istributed Loads
  • Thread starter Thread starter Chandasouk
    Statics
The discussion revolves around ranking the locations of resultant forces applied to a beam under distributed loads. The user initially assumed a beam length of 1 for calculations and identified the centroids of various shapes, concluding that Xc is at 1/3L, Xd at 2/3L, and that Xe and Xf are between L/3 and L/2. The user struggled with determining the centroid of trapezoids and initially provided an incorrect ranking. Ultimately, the correct ranking from smallest to largest is Xc, Xe, Xa, Xb (equal), Xf, and Xd.
Chandasouk
Statics Problem:Distributed Loads
http://imageshack.us/a/img845/5825/112639502.jpg
When measuring from the left side of the beam Xa,Xb ,Xc ,Xd ,Xe ,and Xf are the locations where the resultant force is applied in each of the six cases. Rank these six locations.
Rank the items from smallest to largest. To rank items as equivalent, overlap them.
For this problem, I just made the assumption the L was equal to 1 so I could work with real numbers.
Xa and Xb I found to be the same locations as in 1/2 because they are rectangles.
The centroid of a triangle is 1/3L from its peak, so Xc I said it was 1/3.
Xd = 2/3 since the peak is on the right hand side this time.
I don't know how to find the centroid of the last trapezoids. I just know that Xf > Xe and that they are somewhere in between L/3 and L/2 from a hint in my HW.
The current ranking I have from SMALLEST to LARGEST is
Xc, Xe, Xf, Xa, Xb (they are equal), and Xd but that is wrong. How do I solve this?
When the problem statement said rank the locations of the resultant, it appears it did not specify if they should be ranked from smallest to largest or vice versa.
Sorry about that
I shall also edit my post
This probably doesn't help the person who originally answered the question but the answer is Xc, Xe, Xa, Xb (they are equal), Xf, and then Xd.
