Solve d with Forces/Torque for Statics Problem
  • Thread starter -Dragoon-
  • Tags
    Statics
In summary, the problem involves finding the distance d in the attached image using forces and torque. There is some confusion about whether the torque exerted by the lower beam should be considered positive or negative, but ultimately it does not affect the solution. The key is to properly select the pivot point in order to simplify the problem and eliminate unknowns.
-Dragoon-
309
In the attached image, find d.
N/A
Essentially, I did solve this problem correctly by first using forces and Newton's second law and then finishing it with torque, but I ended up with the wrong answer only because I assumed that the lower beam, which has a force (FG)1 in the diagram, exerts a positive torque since it would try to rotate the system counterclockwise, would it not? Why does my textbook assume that the torque of the lower beam is negative and, thus, would cause a clockwise rotation of the system?
Also, another classmate of mine said this problem could be done much more easily with using the center of mass equations. If they are correct, how would I go about using that method?
attached image: http://imageshack.us/photo/my-images/690/torqueproblem.jpg/
It looks to me like it will rotate clockwise because most of the mass is to the right of the pivot point. What is the question? Show your work so we can offer help!
I've essentially solved the problem, I just wanted to know why they assumed the portion to the right of the pivot of the lower beam is going to try to rotate the system clockwise and thus have a negative torque? Oh, and as I was working through the problem, I separated the two masses so that the upper beam would exert a torque while the lower beam would exert another, just like the book did it.
Sounds good. Maybe "they" took clockwise to be positive. It is difficult to comment without seeing the solution you are writing about.
Yea, clockwise is usually negative. But some authors take it as positive. In this case, check to see if your math and your method is correct. The concept is more important. On a test or HW, you can always define CW and CCW.
Ok, I think posting my worked solution would be the best way to proceed:
Let m be the mass of the lower beam and M be the mass of the upper beam. Let r1 be the distance from the pivot to the application of force of the lower beam and r2 be the distance from the pivot to the application of force. Firstly, I choose the pivot to be the left end of the lower beam to make the problem easier to solve. Using Newton's second laws:
[itex]\sum f_{y} = F_{P} - F_{G_{m}} - F_{G_{M}} = 0[/itex]
[itex]F_{P} = F_{G_{m}} + F_{G_{M}} = mg + Mg = g(m+M)[/itex]
Now to use Newton's second law for rotational statics:
[itex]\sum \tau = \tau_{P} + \tau_{m} - \tau_{M} = 0 => \tau_{P} = -\tau_{m} + \tau{M} [/itex]
[itex]dF_{P} = -r_{1}F_{m} + r_{2}F_{M} => d = \frac{-r_{1}F_{m} + r_{2}F_{M}}{F_{P}} => \frac{-r_{1}F_{m} + r_{2}F_{M}}{g(m+M)}.[/itex]
This is my worked solution. The textbook assumed that the torque exerted by the lower beam is negative, so they had a sum rather than a difference in the numerator of their solution. That assumption is what bothers me, as I thought I was right in assuming the lower beam would attempt to rotate the system counterclockwise.
Any one?
AM I missing something? What are you asked to find? I see the diagram but not the problem?? OK Sorry - find d
Is it in equilibrium?? I assume so.
What's the answer?
What's the answer?
The answer is 1.4 m, I would have gotten the same answer had I made one different assumption: Assuming the gravitational torque exerted by the lower beam that is left of the pivot causes a negative torque and thus tries to rotate the system clockwise rather than counterclockwise, which just doesn't make any sense to me at all.
OK that's what I got only I did a lot less work to get it.
First of all it doesn't really matter which you call positive. Clockwise or counterclockwise. Place the axis of rotation at Point P so the only torques you have are from the two masses (weights) of the plank and the fat plank.
Call the distance from the long plank's weight to P a variable like X This means that the distance from the fat plank's weight to point P will be .5 - x.
You now have two torque you can equate since they act in opposite directions.
The torque from the long plank (about point P)will equal the tgrque from the fat plank (about point P) . Solve for X and add it to the 1.0 meter length of half the long plank and you have d.
Try it like this and see if it doesn't make sense.
The problem was not solving it, but I see it now. I was thinking of the fulcrum as the pivot even though I selected the pivot to be at the left end of the system, in which case the torque of the lower beam would try to rotate the system clockwise just as the torque of the upper beam would.
Thanks for all the help.
The problem usually isn't the math, it's visualizing how to set it up in the first place.
The beauty of a statics problem with torque is that you can put the axis of rotation at the most convenient point to get rid of an unknown, which in this case is the force normal and it makes the distances easier. Other solutions are just as correct, not just as easy.
1. What is the definition of statics in physics?
Statics is a branch of physics that deals with the study of forces acting on stationary objects. It is concerned with the analysis and prediction of the behavior of objects at rest or in a state of constant motion.
2. How do you solve a statics problem using forces and torque?
To solve a statics problem, you need to first identify all the forces acting on the object and their direction. Then, you can use Newton's second law of motion to calculate the net force. To determine the torque, you need to consider the distance between the point of rotation and the applied force. Finally, you can use the equations for equilibrium to solve for the unknown variables.
3. What is the difference between a force and torque in statics?
A force is a push or pull that causes an object to accelerate, while torque is a rotational force that causes an object to rotate around an axis. In statics, forces are used to determine the net force acting on an object, while torque is used to calculate the object's resistance to rotation.
4. How do you know if an object is in static equilibrium?
An object is in static equilibrium when the net force and net torque acting on it are both zero. This means that the object is either at rest or moving at a constant velocity. In other words, the object is not accelerating or rotating.
5. What are some common applications of statics in real-life?
Statics has many practical applications, including designing structures such as bridges and buildings, analyzing the stability of vehicles and machinery, and understanding the forces involved in sports and games. It is also used in fields such as architecture, engineering, and physics.
