Statistical Thermo for Mechies?
Statistical thermodynamics focuses on thermodynamic systems at the micro or atomic level, providing insights into fundamental concepts like enthalpy and entropy. Its applications are relevant in fields involving chemical or thermodynamic processes, such as batteries, gas dynamics, and combustion. While primarily beneficial for those in thermo-fluid-chemical areas of mechanical engineering, it may also appeal to students interested in applied physics. The course is typically offered at the graduate level, indicating a deeper exploration of advanced applications. Overall, it is a valuable subject for those looking to enhance their understanding of thermodynamics in various engineering contexts.
Nspyred
Hi all.
I was perusing the grad course options for mechanical engineering at a local school when I noticed a course in statistical thermodynamics. I know the difference btw classical, chemical, and statistical thermodynamics, and that MEs generally learn classical.
What are the ME applications of a course in statistical thermodynamics? Is it for those in aerospace or nuclear?
Thnx for any replies,
N
I once had the same exact question. Statistical thermodynamics is basically the study of thermodynamic systems on the micro or atomic scale. The reason you want to learn is that it teaches you what all those things like enthalpy, entropy, temperature, pressure, etc actually are. If you're not in the thermo-fluid-chemical side of ME then its probably not worth taking unless you really like math.
The application of stat therm (more commonly called statistical mechanics) is basically anything that involves some type of chemical or thermodynamic process. For example, batteries, gas dynamics, combustion, electrlyzers, etc.
Thanks for the reply ^.
I went back to the school site and noticed that Non-equilibrium thermodynamics is the follow-up course. I am 1st year EE because I want to study electromagnetism/applications, but I also have an interest in thermodynamics-- mainly for applied physics like geophysics, atmospheric physics, solar physics, astrophysics,... That may be where I end up someday...
Given that the course was offered at the graduate level, I imagine that it would be for those who want a deeper understanding of the field for more advanced applications.
Thanks again,
N
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
