Statistical weight (thermodynamics)
The discussion focuses on deriving the equation of state relating pressure (P), volume (V), number of particles (N), and temperature (T) using the statistical weight Ω. The participant initially proposes using the entropy formula s = klnΩ to derive the relationship, leading to P = k2bNVT. However, they are advised to double-check their derivative due to a factor of V within the logarithm, which requires careful differentiation. Additionally, the terms E and N in the equation (ds/dV)E,N indicate that energy (E) and number of particles (N) should be held constant during differentiation. The conversation emphasizes the importance of accurate mathematical handling in thermodynamic equations.
quietrain
find the equation of state which gives the relationship between P , V , N and T
C and b are constants
Ω = CebNV2(EV)N
P/T = (ds/dV)E,N
so i just use s = klnΩ ?
then i get ds/dV = k2bNV
so P = k2bNVT ? that's it?
btw, what does the E and N in (ds/dV)E,N tells me? is it mean keep E and N constant? or the differential is specified by the terms E and N?
thanks!
Ω = CebNV2(EV)N
P/T = (ds/dV)E,N
That seems like the correct method, but double check your derivative. You have a factor of V inside the logarithm, so you should have a second term in your derivative corresponding to differentiating the log(EV) and not V^2
Yes, that is what it means.
ah i see thank you!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
