Statistics - properties of the mean
pointintime
not exactly sure were this goes
ok there was a question that my teacher told me i got wrong
the question asked me to compute the mean which I did...
then the question went on to tell me compute the mean with another observation equal to zero
then the part that he drew the line through was my response to this question
Write a sentence about the effect of the zero on Joey's quiz average that mentions this property...
my response
The property that this illustrate of the mean is the observations. Sense the number of observations increased but the sum of the observations stayed the same this brough down the mean by defintion...
ok he drew a line threw it and told me it was wrong so my question is how is this wrong?
What would a correct answer include?
Thanks for any Help!
Hi pointintime! :smile:
pointintime said:
my response
hmm … the English is bad (but I assume it's a translation?), but apart from that, it looks basically correct …
as you say, the mean is the total divided by the number of observations, and the total stays the same but the number of observations increases. :smile:
The answer the OP gave was probably taken by the instructor to be an observation of the change in this particular case. I think the "property" statement would center on the fact that the mean is not robust (not sensitive, not resistant, depending on the selected terminology); its value can be significantly influenced by a single measurement.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
