What is the Steady State Temperature in a Circular Ring?
Karnage1993
Find the steady state temperature ##U(r, \theta)## in one-eighth of a circular ring shown below:
I start by assuming a solution of the form ##u(r,\theta) = R(r)\Theta(\theta)##. I also note that ##u(r,\theta)## satisfies the equation ##u_{rr} + \frac{1}{r}u_r + \frac{1}{r^2}u_{\theta\theta} = 0## where ##a \le r \le b## and ##0 \le \theta \le \frac{\pi}{4}##. I know that ##r## is bounded, but I am not sure if the temperature is periodic, ie, if ##\Theta(\theta + 2\pi) = \Theta(\theta)##. Where I'm stuck is I do not know how to incorporate the other boundary conditions into what I have, ie, what do I do with the pieces where ##u = 0## and ##u = 100##?
Before worrying about boundary conditions, can you develop the general solution?
Yes, I believe so. (That is for ##0 \le r \le a, 0 \le \theta \le 2\pi##, for some finite ##a##, right?)
The process to get to it is quite lengthy, but I can do it.
Well, then, once you have the general solution use the fact that u(r, 0)= u(r, \pi/4)= 0, for all r between a and b, to solve for two of the constants.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
