Steam Condensation: How Much Steam is Converted to Water at Constant Pressure?
The discussion focuses on the condensation of steam at constant pressure, specifically in a 1 m³ container filled with steam at 100°C and 1 barA pressure. When the temperature is lowered to 70°C, the steam pressure decreases from 101.32 kPa to 31.15 kPa. The calculation indicates that approximately 59.256% of the steam condenses into water based on the pressure change. This percentage is derived from the formula {1-(31.15/101.32)}%. The conclusion confirms that a significant portion of the steam is converted to water under these conditions.
pranj5
What I want to be clarified in this thread is about condensation of steam at constant pressure. Suppose Suppose an enclosed volume of size 1 m³ and it's filled with steam at 100°C and 1 barA pressure. Now, the container is connected to a chamber filled with dry air in such a way that the pressure inside the chamber can't change. Now, the temperature has been lowered to 70°C. Question is, what % of steam will be condensed then.
At 100°C, the pressure of steam is 101.32 kPa while at 70°C it's 31.15 kPa. Does that mean that {1-(31.15/101.32)}% of steam i.e. approx 59.256% of steam has been converted to water?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
14K
24K
10K
