How Is Steam Quantity Converted to Water Volume?
In summary, the conversation revolves around calculating the amount of water produced when steam is condensed in different scenarios. One person mentions that 1000 lbs of steam will condense to 1000 lbs of water, while another person questions the time factor and the specific conditions of the system. As more information is provided, it becomes clear that not enough details have been given to accurately calculate the amount of water produced. The conversation ends with a request for a sketch of the system and more specific information in order to provide a helpful answer.
Waqas
Hi there,
Is there any method to calculate the amount of steam condensed to form water? Let's assume 1000 lbs of superheated steam at 4000C condensed to water at 450C. What will be the amount of water? I have calculated it through specific volume but it returns with a very minimum value.
Hello Waqas, :welcome:
1000 lbs IS an amount of H2O. So 1000 lbs of steam (H2O in vapor phase) will condense to 1000 lbs of water (H2O in liquid phase).
...as long as the pressure in the condenser is over something like half an atm...or there is something else critical we aren't being told...
Thanks for the reply but may be I couldn't state my problem clearly enough. I will try again. In my case, we are inserting 1000 lb/hr steam in a fractionating column. I need to calculate the water produced. Will it return the same flow?
Yes. 1000 lbs of steam will condense to 1000 lbs of water
Likes Waqas
Can you relate this to time? If we release 100 lbs of steam for 1 minute; how much water does that condense to?
Welcome to PF. :smile:
You mention time, but then "how much". Which is it that you want to understand better. As for how much, that's already been answered (you can convert the weight of the water to the volume of water if you want). As for the time, that would depend on how exactly you were condensing it, no?
Then I would need to ask if we use a 2-1/2 inch pipe, at 100 lbs of steam pressure, what is the weight of the water moving through the pipe in 1 minute? Then I can convert to volume.
Our application is that we are blowing down a boiler 3 times a day for 1 minute in total. We are building a blow down tank and have to determine how large it will have to be to store condensed water for a month before it is pumped.
You're getting close to an answerable question. How long is the 2.5 inch pipe? Is there a nozzle on the end? Is the boiler at atmospheric pressure?
Is the 100 PSI steam saturated?
If yes, steam quality or percent moisture in the steam?
If no, then it is superheated; what is the temperature?
Steam temp is 230 degrees.
Pipe is 50 ft long; no nozzle.
Don't know steam quality or MC of steam.
boiler is at atmospheric pressure
I think that the question is not well-formed.
Let's try to answer this. Summarizing the information so far:
Post #6: 100 lbs of steam is released in 1 minute, how much liquid water is that?
Post #8: 100 PSI steam in a 2.5" pipe, what is weight of water?
Post #9: Blowing down boiler 3 times per day for 1 minute total. How much water in 1 month?
Post #11: Steam at 230 deg. Pipe 50 feet long. Boiler at 0 PSIG.
If I take these questions literally, the answers would be as follows:
Post #6: 100 lbs of steam is 100 lbs of water if all of the steam is condensed.
Post #8: It's all steam, so no water. Zero pounds of water.
Post #9: Is that 3 blow downs at 20 seconds each? Or 3 at 1 minute each? No information on boiler pressure, pipe size, pipe length, pipe restrictions, pressure at discharge, or what is blown down. Does boiler blow down release water or steam? At what temperature and pressure? Not possible to answer.
Post #11: Is steam temperature deg F or deg C? What is pressure at pipe discharge? If it discharges to atmosphere, then flow is zero because boiler is at same pressure. If it discharges to a lower pressure, how are you getting the lower pressure? And what is the discharge pressure?
We need the following in order to help you:
1) A sketch of the system. Show the boiler, piping, and what the discharge pipe is connected to.
2) Pressure and temperature at boiler and in blow down tank.
3) Tell us something about the system. For instance, how much water is in the boiler? Anything that will help us to understand what you are doing.
4) Then tell us exactly what you need to know. Is this a complete and correct description of what you need to know?
Please note that every item on my list must be answered before I will respond. You can make a pencil sketch, scan or photograph it to a JPG file, then attach to your response by Attach files > Insert > Full image.
Likes Chestermiller, anorlunda, Tom.G and 1 other person
Waqas said:
Hi there,
Welcome, Waqas! :cool:
Please, see:
https://www.spiraxsarco.com/learn-a...-recovery/introduction-to-condensate-recovery
Hello @rwilson7567 ,
:welcome: ##\qquad##!​
You continue a four year old thread to ask some vaguely related question. Not a good idea.
Furthermore, I am worried considerably about 100 lbs appearing as a pressure in the post above and as an amount of steam in another:
(and by now I guess you don't mean 100 lbs at all -- probably an unknown amount of 689476 Pascal ( :cool: -- in case that looks strange: the pascal is the unit of pressure in civilised countries, but 7 Bara --- or is it 7 Barg ? is an acceptable alternate ) steam of unknown quality (most likely saturated).
Fortunately you are in good hands now (a lot of them!), so I'll switch to listening mode :wink:
Lnewqban said:
Well, this guy wasn't seen for four and a half years, but I'm sure he'll be grateful for a (second) welcome :biggrin:
1. What is steam to water conversion?
Steam to water conversion is the process of converting steam, which is a gaseous form of water, back into its liquid state. This can be done through various methods such as condensation or cooling.
2. Why is steam to water conversion important?
Steam to water conversion is important because it allows for the efficient use of steam in various industrial processes. It also helps to reduce energy consumption and costs as well as prevent damage to equipment that may occur from excessive steam build-up.
3. How is steam converted back into water?
Steam is converted back into water through the process of condensation. This involves cooling the steam until it reaches its dew point, at which point it turns back into liquid water. This can also be achieved through the use of specialized equipment such as heat exchangers.
4. What are the applications of steam to water conversion?
Steam to water conversion has various applications in industries such as power generation, food and beverage processing, pharmaceutical production, and chemical manufacturing. It is also used in everyday household appliances such as steam irons and humidifiers.
5. What are the environmental benefits of steam to water conversion?
Steam to water conversion helps to reduce the emission of greenhouse gases by utilizing steam more efficiently. It also helps to conserve water resources by recycling the same water for multiple uses, rather than constantly using and disposing of fresh water.
  • Thermodynamics
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • General Engineering
12K
  • Classical Physics
