Stellar Classification Limits: Temperature & Magnitude
Stellar classification lacks universally agreed-upon boundaries for temperature and magnitude, leading to significant discrepancies in various charts and tables. For instance, classifications for 'K'-class stars show temperature ranges that vary widely between sources, indicating a lack of consensus. While HR diagrams provide a general framework for categorizing stars, the exact limits for spectral types and luminosity classes remain ambiguous. This variability raises questions about whether stellar classification is inherently subjective or if objective definitions exist. Ultimately, the discussion highlights the need for clearer standards in stellar classification.
ckirmser
Is there a specific limit that defines the boundaries of each classification category?
For example, a main sequence G class star is between X and Y temperatures and has an absolute magnitude between A and B Solar units.
Or, an O hypergiant is between X and Y temperatures and has an absolute magnitude between A and B Solar units.
Along those lines. Essentially, something mathematical that can be used to plug in the characteristics of a star and will produce the classification.
So, if I have a star that has a temperature of 5699K and a Mabs of 0.9M, it pops out with a G2IV (the "2" is just a guess from eyeballing an HR chart).
Or, are the classifications not that explicit?
Astronomy news on Phys.org
In terms of temperature and luminosity that's what the HR diagrams shows, the star's classifications.
Well, yes, but the various charts I've found are not in total agreement on the boundaries.
I've found several tables listing numeric limits for, say, a 'K'-class star, but there is a substantial variance in the listed or pictured properties.
For example, one table I have says a 'K'-class star has a temperature range of 3.5 kK to 5 kK, whereas another has just 5.3 kK, not even an average, but totally outside the bounds listed in the other table.
It looks like stellar classification is a very subjective matter and I'm trying to determine if I am wrong and that there is a set definition that determines a star's spectral type, its luminosity class and its Yerkes class.
If it is truly all subjective, then I can go with that, but I would expect that there are set, objective boundaries.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
