Understanding Stochastic Calculus and Expected Value Formulas
The discussion centers on the expected values associated with a series of coin tosses, where heads yield $1 and tails result in a loss of $1. The expected value of the random variable R_i, representing the outcome of each toss, is calculated to be zero due to equal probabilities of heads and tails. The total winnings S_i after i tosses also has an expected value of zero, while the expected value of S_i squared equals i, reflecting the cumulative variance of the outcomes. The random variable R_i is identified as a Bernoulli Random Variable, with outcomes of 1 and -1, leading to the conclusion that, over time, the average winnings will balance out to zero. This understanding of expected value and variance is crucial in stochastic calculus.
courtrigrad
Hello all
If you throw a head I give you $1. If you throw a tail you give me $1. If R_i is the random amount ($1 or -$1) you make on the ith toss then why is: E[R_i] = 0, E[R^2_i]=1, E[R_iR_j] = 0? If S_i = \sum^i_{j=1} R_j which represents the total amount of money you have won up to and including the ith toss, then why does E[S_i] = 0, E[S_i^2] = E[R_1^2 + 2R_1R_2 + ...] = i? I know that if there had been five tosses already then E[S_6|R_1,...,R_5] = S_5
Any help is appreciated
Thanks
I know that Expected Value is defined as: E[X] = \sum_x f(x)P(x) for a discrete variable.
Right, and Ri is what is called (in my probability theory class I'm taking anyways) a Bernoulli Random Variable. There are only two possible outcomes: success, or failure, usually denoted by 1 or 0 respectively. However, since Ri represents the winnings, and they are -1 for tails, the expectation, given your definition is (letting H denote a heads and T a tails):
E[X] = \sum_x xp(x) = 1\cdot P(H) -1 \cdot P(T) = 1/2 - 1/2 = 0
The expectation can be interpreted as the average value (ie the value expected over time) that the random variable takes on. For a random variable that can only take on the values 1 and -1, what is the average? Since both outcomes have equal weighting (p = 1-p = 1/2), on average you'd expect no net winnings, since the chances of getting a dollar are about equal to that of having to pay up. I hope this gets you started. Now consider the other cases: what is Ri squared? Well, what is 1^2? What is (-1)^2?
ETC...
