Validating Stokes' Theorem Formula for Triangular Surface on y-z Plane?
  • Thread starter Thread starter JB91
    Formula Theorem
JB91
Show that both sides of the Stoke's Theorem formula are valid for the function F= using the triangular surface on the y-z plane with corners at the origin, (0,2,0) and (0,0,2).
Stokes Theorem equation( not sure how to write it out here) [/B]
Took the curl of V, ended up with <-2y,-3z,-x> but when I go to integrate do I set x=0 and then dx=0 as well? So then, with y=2-z , bounds on the integrals are 0-2 and 0-(2-z) so (INT)(INT)(-3z)dydx with the bounds? But when I do this I end up with -4 ... Not sure where I am going wrong and I don't know how to prove the other side of the equation. Any help would be greatly appreciated.
JB91 said:
1. The problem statement, all
and given/known data
You left out the function so we can't answer your question!
Duplicate thread to https://www.physicsforums.com/threads/stokes-theorem.806286
The name is "Stokes", not "Stoke". So it should be "Stokes' theorem".
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
