Stone-Weierstrass, uniform convergence
holomorphic
Show that there are continuous functions g:[-1,1]\to R such that no sequence of polynomials Q_n satisfies Q_n(x^2)\to g(x) uniformly on [-1,1] as n\to\infty
Suppose there is a sequence Q_n such that Q_n(x^2)\to g(x) uniformly for g(x)=x.
Then \forall \epsilon > 0 \forall x \in [-1,1] \exists N:(n\geq N\Rightarrow |Q_n(x^2) - g(x)| \leq \epsilon)
Take \epsilon = 1/2. Then \exists N_1, N_2 : ( n \geq max\{N_1,N_2\} \Rightarrow |Q_n(1^2) - g(1)| \leq 1/2 and |Q_n((-1)^2) - g(-1)| \leq 1/2).
Then for n \geq max\{N_1,N_2\} we have
1 = 1/2 + 1/2 \geq |Q_n(1^2) - g(1)| + |Q_n((-1)^2) - g(-1)|
=|Q_n(1) - g(1)| + |Q_n(1) - g(-1)|
\geq |g(1)-g(-1)| = |1+1| = 2, which is false. Therefore there is no such Q_n.
Does this solution make sense?
Oops. I used pointwise convergence instead of uniform. Doesn't change much but this should have read:
Then \forall \epsilon > 0 \exists N: \forall x \in [-1,1], (n\geq N\Rightarrow |Q_n(x^2) - g(x)| \leq \epsilon)
Take \epsilon = 1/2. Then \exists N : ( n \geq N \Rightarrow |Q_n(1^2) - g(1)| \leq 1/2 and |Q_n((-1)^2) - g(-1)| \leq 1/2).
Then for n \geq N we have
It certainly makes sense. I haven't gone through all the details, but the main idea is surely correct.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
