Stopping the Bus in 100m - Can it be done?
  • Thread starter Thread starter chwala
    Bus
The discussion centers on whether a bus can stop within 100 meters, with calculations showing it can stop in approximately 88.91 meters under ideal conditions. The method used involves determining the time to stop using the formula v = u + at and calculating the distance traveled during that time. An alternative approach using the v² formula is mentioned, which simplifies the process by not requiring the stopping time. However, the importance of accounting for the driver's reaction time is highlighted, suggesting a more realistic stopping distance of 96.91 meters when factoring in an additional 8 meters for reaction time. Ultimately, while the bus can theoretically stop in time, real-life conditions necessitate considering reaction delays.
chwala
See attached.
##s##=##ut##+##\frac{1}{2}at^2##
Find the question and its solution below;
Find my approach here;
The bus needs to stop at the point where, ##v=0##, therefore we need to find the time taken for the car to come to a stop. using
##v=u+at##
##0=26.67 + (-4)t##
##t##=##\frac {-26.67}{-4}##=##6.6675## seconds
The distance traveled at time, ##t##=##6.6675## is given by;
##s##=##177.822+ (-88.91)##=## 88.91metres< 100 metres##
Conclusion
Yes, the driver can stop in time.
Any other way of looking at this is highly appreciated.
chwala said:
Conclusion
The other ways of looking at this are given in the solution of the textbook.
Likes robphy and chwala
@chwala , your method is better if you want to include the driver's reaction time.
Otherwise the book's solution is more direct (assuming you know the v^2-formula)
since one doesn't have to calculate the stopping time (since no one asked about it).
If you substitute the general expression [for constant acceleration] ##t=(v-u)/a##
into your ##s##-equation [for constant acceleration], you'll get their ##v^2##-formula [for constant acceleration]. (Try it.)
Likes chwala and DrClaude
Thanks, I am conversant with the ##v^2##-formula approach.
The author indicates that we ought to add ##8## to the final solution as in real life situation; it is highly unlikely to apply the brakes spontaneously after seeing the bus...it takes a few moments...
i.e even after adding;
##[8+88.91=96.91]m<100m##.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
