Stress analysis -- derive equations: bending & yielding
The discussion revolves around deriving equations for bending and yielding in a mechanical engineering context, specifically focusing on a beam under plane stress conditions. The participant, an alloy chemist transitioning into materials engineering, is struggling with the concepts and equations related to stiffness and bending moments. They highlight the importance of understanding shear and moment diagrams and suggest starting with a free body diagram for clarity. The conversation also touches on design optimization, emphasizing the need to balance material mass, stiffness, and strength while considering production costs. Overall, the thread seeks guidance on applying theoretical principles to practical problems in materials engineering.
Strife_Cloud
Problem attached.
I would appreciate anyone's help. I am an alloy chemist working on an MS degree in materials engineering and have come to the mechanical engineering part of the program and am feeling a bit behind. Deriving an equation for this case is proving to be difficult for me although I believe we are still at the elementary mechanical review period.
The basic situation is that of plane stress with an "important focus" on stiffness. The class is following the mechanical behavior of materials book by Dieter. I have a lot of time putting the pieces together but an now a bit stumped.
All you appear to have in this problem is a simple beam in bending but I can't make much sense of the actual questions at all .
Have you any more information ?
Likes Strife_Cloud
With the subtlety that this panel will be stiffer than a beam because it cannot contract laterally (because of its large width). I wrote a summary of generalized[/PLAIN] Hooke's Law for solving problems like this. It looks like the questions are essentially aiming at a design optimization problem in which the mass of the panel might be minimized while maintaining a given stiffness (in (b)) and strength (in (c))? But "bending momentum" is not a term I'm familiar with; I suppose it's meant to mean the bending moment.
Strife_Cloud, I'd start with a free body diagram of the panel. Have you covered shear and moment diagrams? If so, draw these too. Then find the stress at the bottom of the panel at the middle.
Likes Strife_Cloud
Yes, we are going to be using this example to compare different materials and focus on what material we should consider. Then factoring in cost of materials and what processes are involved in production and how that leads to the properties of the final product.
The image is what he posted online to be completed before class. Adding that, we would use the equations we derive evaluating materials for the depicted stress state.
Unfortunately, that is all the information given on the sheet so I have been attempting to go through all of the variables we have been given hoping the combination leading to the equation will click but, it hasn't yet. I look forward to reading the information on the link provided and I will let you know how it helps! Thank you both for responding and for your help!
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
14K
