Stress Analysis Student Project
The discussion centers on performing a stress analysis of helicopter landing gear, focusing on design improvement and material selection to enhance strength under stress. The original poster seeks guidance on methodologies for analysis and redesign, especially considering financial constraints. Suggestions include choosing a helicopter with fixed skids instead of wheels for a more straightforward analysis. The poster also requests recommendations for user-friendly software to visualize stress and shear regions. Overall, the conversation emphasizes the importance of understanding dynamics and material properties in engineering analysis.
ozgurakkas
Hi All,
I am going to perform stress analysis on a helicopter landing gear. My job is to find one specific landing gear, study its design, analyze and through tools we learned in the strength of materials class, redesign the gear to improve it.
If you have knowledge of this sort of engineering analysis, can you suggest me some guide lines. For example, how do I increase strength in bearing the stress. Is it possible just by choosing another type material. How would I approach to this If there were financial constraints.
I am also trying to show the improvisation through a computer program. For example, landing gear stress and shear regions before and after. Can you suggest me a program, perhaps one easy-ier to figure out?
It s been a long post. Thank you for your patience and suggestions.
Rugzo
If you have a free choice about the type of landing gear, I suggest you choose a helicopter that has fixed skids for landing, not wheels. In a "strength of materials" type of course, you may not have studied all the things that are important to analyze and redesign wheeled landing gear.
If you have studied the dynamics of multi-degree-of-freedom systems including damping, and their response to impulsve loads, then you can ignore my advice, but I would guess that you haven't studied those things in a strength of materials course, as compared with an BS level Mech Eng dynamics course.
This was helpful. I will take your suggestion into consideration. Thank you.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
