Calculating Spring Constant from 52N Force and 0.73m Stretch
  • Thread starter StephenDoty
  • Tags
    Spring
In summary, the value of the spring constant is 71 N/m and it is pulling in the opposite direction of the stretch, which is to the left in this scenario. This means that if the spring is pulled to the right, it will pull back to the left with a force of 71 N/m.
StephenDoty
265
A force of 52N stretches a spring 0.73m from equalibrium. What is the value of the spring constant?
F=-k * delta s
52N= -k * 0.73m
52N/0.73N = -k
k= -71.2 N/m or -71 N/m with sig figs.
The negative sign means that the force is opposite of the stretch.
Is this right?
Of course it's right.
The spring constant k will be a positive number.
The force F in Hooke's law is the force of the spring, not the external force that pulls on the spring. Also, F and (delta s) are vectors so we need to keep track of their directions.
So, just to pick a specific direction, let the spring be pulled to the right, and also choose rightwards to be the positive direction. Then (delta s)=+0.73m. But to get the sign of F we need to find which direction the spring is pulling.
So:
both the force and the displacement are in the same direction since the sping is being stretched, but the k constant is pulling in the opposite direction so k = 71 N/m pulling the spring in the opposite direction of the stretch.
If you pull a spring to the right, the spring pulls back against you to the left. So if delta s is positive, then F is negative.
ok..
-52N=-k*0.73m
-52N/0.73m = -k
-71 N/m = -k
71 N/m = k
Which is what I got before.
If my posts made it seem like I was saying the magnitude of your answer was wrong, I definitely did not intend that. I was just pointing out that the sign of your original answer was wrong, and that it might be coming about because maybe you were thinking that F was the external, applied force when it is really the force of the spring.
1. How do you calculate the spring constant using a 52N force and 0.73m stretch?
To calculate the spring constant, we can use the formula K = F/x, where K is the spring constant, F is the applied force, and x is the amount of stretch or displacement of the spring. In this case, we can plug in the values of 52N for F and 0.73m for x to get a spring constant of approximately 71.2 N/m.
2. What is the unit for spring constant?
The unit for spring constant is Newtons per meter (N/m). This represents the amount of force required to stretch the spring by one meter.
3. Can the spring constant change?
Yes, the spring constant can change depending on factors such as the material, length, and thickness of the spring. It can also change if the spring is stretched beyond its elastic limit, which causes permanent deformation.
4. Is the spring constant the same for all springs?
No, the spring constant can vary for different types of springs. For example, a steel spring will have a different spring constant than a rubber band. It also depends on the shape and size of the spring.
5. How is the spring constant useful in real-life applications?
The spring constant is important in various real-life applications, such as in the design of suspension systems in vehicles, shock absorbers, and measuring devices. It is also used in engineering and physics experiments to study the properties of materials and to determine their strength and elasticity.
