Tension in a Rope: Understanding Acceleration in Lifting a Bucket of Water
  • Thread starter Thread starter izmeh
    Spring Strings
To determine the tension in the rope while lifting a 4.25-kg bucket of water with an acceleration of 1.80 m/s², one must consider both the upward tension and the downward gravitational force. The net force acting on the bucket can be expressed using Newton's second law, where the net force equals mass multiplied by acceleration (Fnet = ma). The weight of the bucket, calculated as mass times gravitational acceleration (mg), must be subtracted from the tension to find the net force (Fnet = T - mg). By substituting the known values into the equations, the tension in the rope can be calculated. Understanding these forces is essential for solving the problem accurately.
izmeh
I have the following problem
Pulling up on a rope, you lift a 4.25-kg bucket of water from a well with an acceleration of 1.80 m/s². What is the tension in the rope?
What part exactly does the acceleration play in this scenario?
The net force on an object determines its acceleration. Given the acceleration, you can find the net force. Tell us what you know about Newton's second law.
net force = ma
a = f/m
1.80 = f/4.25
f = 7.65
First step: Describe all the forces acting on that bucket! Then add them up to find the net force.
Draw yourself a diagram.
there is the force of me pull it up @ 1.80m/s²
the mass 4.25 pulling down...
There is a force pulling up, that's the tension (T) in the rope. There's also a force pulling down, the weight (not mass!) of the bucket&water. (Note: gravity pulls on the mass, that pull is the weight. You can calculate the weight by multiplying the mass by g, the acceleration due to gravity. g = 9.8 [m/s2])
The net force is (choosing up as positive):
Fnet = T - mg
From Newton's second law:
Fnet = ma
Now it's your turn. You know a (it's 1.8 m/s2 upwards) and you know m . Find T. Give it a try.
