Stuck on equating co-efficents DiffEQ
  • Thread starter Thread starter mr_coffee
    Diffeq Stuck
mr_coffee
I'm confused on how to equate coniffecents. What I'm doing is, finding a particular solution for just the polynomial then I'm going to find it just for the exponential and add them together rather then putting it all together and making it a mess, but I'm stuck when i try to add the Co-efficents, can someone explain that process to me? Thanks!
Here is my work!
http://suprfile.com/src/1/1ta5k1/lastscan.jpg
I kinda see.
Fact: Two polynomials are equal iff their respective coefficients are the same. (You might want to try proving this (hint set x=0. u get 1 relation, differentiate, set x=0, u get a second equality, differentiate, set x=0, etc))
This is what you have here. So you want to rewrite the LHS as
-At^2 + (2A-B)t + (12A+B-C) = t^2 + t
Now what the theorem/fact stated above is telling you is that
-A=1
2A-B=1
12A+B-C=0
It's a linear system of equation. Start row-reducin' friend!
THanks man worked great!
There is another method: just plug-in three different values of t (like, say t=0,1,2,) into the given equation to generate three equations in A,B, and C.
shweet.
thanks for the tip
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
