Stuck understanding Bernoulli's Principle, would love some help
Bernoulli's Principle explains how pressure and speed of air interact, but it isn't the primary reason sailboats can move faster than the wind. Sailboats cannot sail directly into the wind, but they can achieve higher speeds by utilizing the wind's energy efficiently. Low-drag vessels, like ice boats, can exceed wind speed due to minimal resistance, while certain vehicles can achieve speeds up to three times the wind speed by using wheels to drive a propeller. The key to these high speeds lies in the craft's ability to slow down the wind, whether through sails or propellers. Understanding these dynamics is crucial for grasping how wind-powered vehicles operate effectively.
avidstr
Hi all - I was having a debate with some students in my flipped class today and I can't wrap my head around Bernoulli's Principle as it relates to the sea.
Can anyone explain how Bernoulli's principle works with a sail boat? I don't know how the force vectors resolve to push a sail boat faster into the wind than with the wind.
Thanks so much for any help!
A sailboat can't sail directly upwind. A very low drag sailboat may be able to tach downwind such that the net downwind speed is greater than the wind speed. A better example would be an ice boat, where there is very little drag, and these can achieve downwind speed component much greater than the wind speed. There are also directly down wind faster than the wind (DDWFTW) vehicles that use the wheels to drive a propeller, and these can also go faster than the wind, with a full scale model achieving close to 3x wind speed with a wind around 10 mph. This works because the wind speed versus the ice / ground / water speed remains the same regardless of how fast the craft moves. Bernoulli equation approximates the amount of pressure versus speed of the air as the air is deflected by a sail or wing, but it's not the key reason for the high speed that these craft can achieve, other than for these vehicles to work the sail or drive train and propeller need to be efficient. Wind powered vehicles get their energy by slowing down the wind. It doesn't matter if the wind is slowed down directly by the sail or propeller, or slowed down due to an upwind component of the wash of air diverted by a sail or accelerated by a propeller.
Other threads with links to even more threads:
https://www.physicsforums.com/showthread.php?t=562993
https://www.physicsforums.com/showthread.php?t=421733
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
