B Calculating Rod Speeds with Algebraic Formulas
A user is attempting to create a spreadsheet formula to calculate rod speeds using algebraic expressions after a long absence from high school math. They need to rearrange the formulas w=(d/r)/t and v=d/t to find v2 when given r2, with known values for v1 and r1. The discussion provides a solution, showing that v2 can be calculated as v2 = (v1 * r2) / r1, assuming that the ratio of velocities and radii remains constant. The context involves analyzing how the length of a rod affects the speed at one end when swinging around an axis. The user plans to have the calculations verified by an engineer before implementation.
demackison
I am trying to create a formula for a spreadsheet to calculate values and it has been thirty years since high school algebra. Here are the formulas I need to rearrange.
w=(d/r)/t
v=d/t
w is an unknown constant and I have values for v1 and r1
I need the formula to spit out v2 if I input r2 in the spreadsheet
Mathematics news on Phys.org
We normally don't give away ready made answers, but in this (very simple) case I'll make an exception, as it seems, that a tutorial on how to deal with quotients might not be appropriate in your case. But in general please use our homework section for these kind of questions, the automatically inserted template and especially tell us, what you don't understand, i.e. where you got stuck and why.
##w=(d/r)/t = \dfrac{\frac{d}{r}}{\frac{t}{1}}=\dfrac{d}{r} \cdot \dfrac{1}{t}= \dfrac{d}{r\cdot t}=\dfrac{d}{t} \cdot \dfrac{1}{r}=\dfrac{v}{r}##.
So if ##\dfrac{v_1}{r_1}=w= \dfrac{v_2}{r_2}## then ##v_2= \dfrac{v_1}{r_1}\cdot r_2 = \dfrac{v_1 \cdot r_2}{r_1}##.
Thanks!
demackison said:
Thanks!
I had converted to d/r * t/1, in error.
demackison said:
Thanks!
Only if ##\frac{d_1}{r_1}=\frac{d_2}{r_2}## but you haven't explained anything about the assumptions which are allowed or not, especially nothing about ##d##. That's why I said: If ##\frac{v_1}{r_1}=\frac{v_2}{r_2}##. I cannot know.
The formula was for a rod swinging around an axis with the speed of one end of the rod known. In essence, the spreadsheet will show what various longer or shorter rods will do to the speed at the other end.
Don't worry, this will be checked by an actual engineer before anything is implemented. :)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
