Stumbling Upon Pi: Could a Billion 3's be Hidden Inside?
  • Context: Undergrad
  • Thread starter Thread starter rmberwin
    Pi Randomness
The discussion revolves around the concept of whether a sequence of a billion 3's can be found within the digits of pi, exploring the properties of normal numbers and the nature of irrationality. Participants examine the implications of pi being indistinguishable from a random series of digits and the conditions under which certain sequences might appear.
  • Some participants propose that since pi is indistinguishable from a random series of digits, a billion 3's could potentially be contained within it.
  • Others argue that the property of being a normal number, which implies that every finite sequence appears infinitely often, is relevant but remains unproven for pi.
  • A participant mentions that while irrational numbers exist, not all irrational numbers are normal, highlighting the complexity of the topic.
  • There is a discussion about the nature of binary code and its relation to decimal expansions, with some participants clarifying that binary is a number system, not merely a code.
  • Some participants express uncertainty about the implications of irrationality and whether it guarantees the presence of any sequence within a number.
  • A later reply questions the assertion that pi is indistinguishable from a random series of digits, suggesting that this statement may not be proven.
  • Another participant introduces the idea of computable numbers, discussing algorithms that can generate series converging to pi, which raises questions about the randomness of pi's decimal expansion.
Participants express multiple competing views regarding the properties of pi, normal numbers, and the implications of irrationality. The discussion remains unresolved, with no consensus on whether pi contains a billion 3's or the nature of its digit sequence.
Limitations include the unproven status of pi's normality and the complexities surrounding the definitions of normal and computable numbers. The discussion also touches on the nature of rational and irrational numbers without reaching definitive conclusions.
rmberwin
Let's say we randomly select integers to construct a potentially infinite number, for example 3588945... There is a non-zero chance that eventually we will obtain any possible finite series of numbers, say a billion 3's in a row. It is known that pi is indistinguishable from a random series of digits. Does this mean that a billion 3's in a row are contained in pi? Think Carl Sagan's novel Contact.
The answer is: we don't know. The property you're referring to is called that of a normal number.
http://en.wikipedia.org/wiki/Normal_number
So roughly speaking, a normal number is a random collection of digits. Every digit appears as many times as the other. Every pair of digits appears as many times as other pairs, and so on. In particular, a sequence of a billion three's will appear infinitely many times. Furthermore, if you take all the works of Shakespeare and express it in binary, then somewhere in the normal number, this work of Shakespeare will appear.
Allmost all numbers are normal, but very few numbers have been shown normal. One example is the Champernowne's constant:
[tex]0.12345678910111213141516...[/tex]
http://en.wikipedia.org/wiki/Champernowne_constant
At this point of time, it remains unproven whether ##\pi##, ##e## or ##\sqrt{2}## is normal. It probably is, but it might not be so. We'll have to wait until a mathematician finds a proof or disproof.
Tragically, we failed to recognize the aliens because they sent us the digits of Tau.
I think that it is possible to find any amount of any number as many times as you like seeing that Pi is an irrational number.
Irrationality has nothing to do with it. For example, the number
[tex]0.11010010001000010000010000001...[/tex]
is irrational but does not contain "any amount of any number as many time as you want".
Thank you, but if if irrationality does not matter then what type of number is it in this situation?
What you're thinking of is probably a "normal number". Any normal number is irrational, but not every irrational number is normal. It is currently unkown whether ##\pi## is normal.
Does binary code exist after the decimal point? (Not saying that what you typed is binary code)
Could you expand on that question, since I have no idea what you mean.
Thank you very much.
I mean, since Binary Code is a string of 1's and 0's is it just a code or is it a long number that can go into decimals.
Base 2 number system works just like the base 10 number system. You can have fractions, decimals, whole numbers, etc. That is, it is NOT a "code" it is a radix number system.
A number is rational if its decimal expansion is ultimately repeating.
So it is easy to make irrational numbers.
For instance the number whose 2^nth place is 1 and all other places are zero is irrational.
Ah, I see, this is _for all n_ .
WWGD said:
Isnt this the number ## \frac {1}{10^{2^n}} ## ?
He meant a number for each ##n##, not a particular one.
Yeah. I meant for every n so it would be
.1001000100000001 ...
Yes, I just realized that, should have been obvious to me.
I can delete my dumb post if you all want, to get rid of the noise.
But an interesting point, lavinia, maybe, is that your irrational number is a(n) (obviously infinite) sum of Rationals.
WWGD said:
But an interesting point, lavinia, maybe, is that your irrational number is a sum of Rationals.
Every real number can be written as the (infinite) sum of rationals
Yes, I know, just to comment that Rationals are not close under infinite sums, and Irrationals are not even under finite sums: x-x =0. But the issue too is the speed of the convergence to decide if the limit is Rational or Irrationals.
I don't think this is known. I'm not sure if this statement is equivalent to "pi is a normal number", but either way I don't think this is proven.
Here is a thought/question.
There are simple algorithms that generate infinite series of rational numbers that converge to π. By going out far enough on one of these series, one obtains a rational number whose first n decimal places are the same as those for π. So it would seem then that the decimal expansion of π is not random in some sense because it is computable.
It would also seem that for most numbers there is no such algorithm - proof? - so most numbers are truly random but π is not.
If statistically, the decimal expansion of π were indistinguishable from a random sequence, then I am reminded of mechanical systems (chaotic systems) which statistically appear random but in fact are completely determined.
- I imagine that the concept of an algorithm needs defining; perhaps an inductive rule that requires only a finite amount of initial data. But I am out of my element here.
- I just found this Wikipedia link on what are called "computable numbers". The definition involves Turing machines. Perhaps someone can explain what it means but it seems to mean something like there exists a computer program that generates a series that converges to the number.
http://en.wikipedia.org/wiki/Computable_number
In any case, by this definition,π is "computable", as also is e but in total there are only countably many computable numbers. Interestingly, the computable numbers from a subfield of the real numbers.
Yes if by obviously you mean an inductive algorithm. I had the same thought. Look at my post about computable numbers just above.
I believe what is meant by this is that the probability of finding a number at a position in pi is the same as if you just randomly assembled the numbers and looked at that same position.
  • · Replies 67 ·
16K
  • · Replies 175 ·
28K
