What Will the Clock Read at the Turnaround Point in the Twins Paradox?
  • Thread starter Thread starter Al68
    Stupid
Al68
If we add a third observer to the twins paradox at the turnaround point (at rest with earth), and with a clock that was synched with the other two when the ship left earth, what will that clock read when this third observer sees the ship turn around?
Assuming v= 0.8c, distance = 8 ly.
Also, since this third observer and the ship's twin could look at each other's clocks (locally), what would each observe the other's clock to read?
Thanks,
Al
Do you mean... the third observer and the Earthbound twin have synchronized their clocks according to Einstein's convention? Or equivalently, measuring simultaneity relative to an inertial coordinate chart where both the third observer and Earthbound twin are stationary, their clocks read the same value at the same (coordinate) time?
Just choose a coordinate chart and compute! (An inertial coordinate chart centered on Earth is probably the simplest)
As measured by what coordinate chart?
Again, just select coordinates and compute!
In what way are you having trouble making the calculations?
Thanks for your thoughtful and complete answers to my questions.
Al
You're welcome. But I did not intend to give a complete answer, but instead help you take this opportunity to gain experience through doing the problem (or to help correct whatever was preventing you from being able to do so, if appropriate). I apologize for denying you that opportunity, and will try harder to avoid spoiling the next problem.
Oh, don't worry, you didn't deny me that opportunity. After all, I had that opportunity before I ever posted. So don't worry, your detailed answers didn't spoil it for me.
Al
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
