MHB Apparent Size of Sun: Subtended Angle Calculated by Deniz
  • Thread starter Thread starter veronica1999
    Angle
Deniz calculates the apparent size of the Sun by comparing it to an aspirin tablet held at arm's length. The angular size of the tablet is determined to be \(7/800\) radians, which is equivalent to approximately 0.501 degrees. This calculation aligns with the known fact that both the Sun and the Moon have an angular diameter of about half a degree. The discussion emphasizes the relationship between the size of objects and their distance from the observer in terms of angular measurement. Overall, the calculations confirm the commonly accepted angular size of the Sun.
veronica1999
Deniz notices that the Sun can barely be covered by closing one eye and holding an
aspirin tablet, whose diameter is 7 mm, at arm’s length, which means 80 cm from Deniz’s
eye. Find the apparent size of the Sun, which is the size of the angle subtended by the Sun.Could I get some hints pls?
Thanks
Mathematics news on Phys.org
Thanks
The angular size of the asprin at arms length is \(7/800\) radian, which is equal to the angular size of the sun.
Converting to degrees this is \((7/800)\times(180/\pi)\approx 0.501^{\circ}\), which agrees with what everyone should know: that the sun and moon have an angular diameter of about a half degree.
CB
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
